![]() | Home > Maintenance & Mods (L322) > Error codes, help appreciated |
paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44 ![]() ![]() ![]() |
hi , yes that code is a common fault , it's located on the RHS exhaust manifold as you look at the engine from the front . There is a very good thread on wiki under egr temp sensor ( which it isn't ) . I had that fault for 2 years on my car without issue .
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic50202.html
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
Thanks guys much appreciated, should have done a search |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Just seen this thread Ross...
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Yep, we’ve all got it or had it |
It always nagged away at me seeing that code even though i had no issues . In the end i had it swapped at Duckworths as part of some other work i had done , having no error codes makes me happy ( and poorer |
It makes good sense to change it at the same time as other work if access is easier, depending on the job you are getting done.
