Home > Maintenance & Mods (L322) > Error codes, help appreciated
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Had to call the RAC today, was a fuel code but didn't have my iiD with me, all sorted with a reset, However this code came up which he assured me is a problem, any thoughts??
DTC: P040D,Exhaust Gas Recirculation Temperature Sensor "A" Circuit High
Thanks Thumbs Up
Post #564936 18th Aug 2020 7:10pm
paulwlincs
hi , yes that code is a common fault , it's located on the RHS exhaust manifold as you look at the engine from the front . There is a very good thread on wiki under egr temp sensor ( which it isn't ) . I had that fault for 2 years on my car without issue .
If you fancy changing it it's a challenge , i would suggest leave it alone .
Post #564995 19th Aug 2020 12:54pm
GGDR
https://www.fullfatrr.com/forum/topic50202.html
Fine to leave it Cheers, Greg
Post #564996 19th Aug 2020 1:20pm
Rosco
Thanks guys much appreciated, should have done a search Bow down
Post #565011 19th Aug 2020 3:07pm
Baltic Blue
Just seen this thread Ross...
Join the club Rolling with laughter ... mine has had this fault code showing since I bought an iid at least 3 years ago.
Even my local independent garage told me to ignore it....They said it’s a pig of a job and can even mean needing a new manifold if things go badly.
Cheers
Post #565012 19th Aug 2020 3:17pm
DrRob
Yep, we’ve all got it or had it Thumbs Up
I had mine swapped out as part of some wider jobs (new secondary turbo) by Rovertune who have the kit and experience and regularly swap them out for the upgraded sensor replacement Thumbs Up
Personally, I’d ignore it unless you want to have a go and follow Greg’s excellent guide Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #565016 19th Aug 2020 4:39pm
paulwlincs
It always nagged away at me seeing that code even though i had no issues . In the end i had it swapped at Duckworths as part of some other work i had done , having no error codes makes me happy ( and poorer Rolling Eyes ). 2011 tdv8 4.4 vogue Santorini black
Post #565060 20th Aug 2020 8:19am
Baltic Blue
It makes good sense to change it at the same time as other work if access is easier, depending on the job you are getting done.
Post #565061 20th Aug 2020 8:27am
