Home > Maintenance & Mods (L322) > Error codes, help appreciated |
paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44 |
hi , yes that code is a common fault , it's located on the RHS exhaust manifold as you look at the engine from the front . There is a very good thread on wiki under egr temp sensor ( which it isn't ) . I had that fault for 2 years on my car without issue .
19th Aug 2020 12:54pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
https://www.fullfatrr.com/forum/topic50202.html
19th Aug 2020 1:20pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
Thanks guys much appreciated, should have done a search |
19th Aug 2020 3:07pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
Just seen this thread Ross...
19th Aug 2020 3:17pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Yep, we’ve all got it or had it
19th Aug 2020 4:39pm |
It always nagged away at me seeing that code even though i had no issues . In the end i had it swapped at Duckworths as part of some other work i had done , having no error codes makes me happy ( and poorer ). 2011 tdv8 4.4 vogue Santorini black |
20th Aug 2020 8:19am |
It makes good sense to change it at the same time as other work if access is easier, depending on the job you are getting done.
20th Aug 2020 8:27am |
