Home > Maintenance & Mods (L322) > Dents in Door Shuts
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Dents in Door Shuts
My quest for a decent L322 continues. A relatively minor issue, but the three I have viewed so far all have minor dents in the door shuts. I can only assume this is due to seatbelt buckles being trapped as door is slammed shut. If my assumption is correct, is this just carelessness or are the seatbelts not retracting correctly? Any comments appreciated.
Post #564092 10th Aug 2020 10:44am
DrRob
Ditto. Same here. Not visible when shut so not too worried.
Look underneath for oil leaks instead Whistle Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564094 10th Aug 2020 10:58am
Yes caused by seatbelts shut in rear doors...
Im unsure if its by kids that have never been taught any worth or mechanical sympathy? Or caused later in the vehicles life when the seatbelts have become weaker and don't retract in time???
Either way, i have fitted tonnes of rear and front seatbelts for just this reason... Thumbs Up
Post #564100 10th Aug 2020 11:40am
RR2B
Thanks - it is a long way down on my list of 'things to be bothered about'!
Post #564101 10th Aug 2020 11:43am
bishbosh10
Even if it is a lazy seatbelt it is easy to replace them at home - about £100 for a front belt IIRC. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #564111 10th Aug 2020 1:24pm
Gunni
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
Similar issue with mine when I bought it. Pull it all the way out and use a little silicon spray.
Still working fine 2 years later.
Jon Jon
2009 3.6 TDV8 Vogue SE
Previous Land Rovers
Series 2 Land Rover petrol - loved it and want another
Range Rover classic v8 - loved it But glad i sold it
Series 3 Land Rover - Steering lottery But useful.
Land Rover v8 90 - Fast dirty & drank Fuel like a Boeing 737.
Post #564131 10th Aug 2020 6:11pm
DrRob
Jon
Where do you spray? The end of the belt ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #564134 10th Aug 2020 6:17pm
Gunni
Pull the belt all the way out. Light spray the first foot of it to start with and the areas where it runs through.
See if that’s enough. If not go a bit further.
Usually it gets enough speed at the start to get the rest pulled back.
Trial and error but cheaper than a new belt.
You will need some silicone spray for door/boot seals anyway so it’s worth a try. Jon
Post #564142 10th Aug 2020 7:04pm
DrRob
Post #564144 10th Aug 2020 7:15pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Land Rover products do not leak!
They simply mark their territory.😀
Post #565478 25th Aug 2020 6:44pm
