![]() | Home > Maintenance & Mods (L322) > Dents in Door Shuts |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Ditto. Same here. Not visible when shut so not too worried.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
Yes caused by seatbelts shut in rear doors...
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 254 ![]() ![]() ![]() |
Thanks - it is a long way down on my list of 'things to be bothered about'! |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Even if it is a lazy seatbelt it is easy to replace them at home - about £100 for a front belt IIRC. Bish.
Gunni Member Since: 13 Jan 2018 Location: Dorset Posts: 16 ![]() ![]() ![]() |
Similar issue with mine when I bought it. Pull it all the way out and use a little silicon spray.
Jon
Pull the belt all the way out. Light spray the first foot of it to start with and the areas where it runs through.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Land Rover products do not leak! They simply mark their territory.😀 |
