![]() | Home > Maintenance & Mods (L322) > Viscous fan removal TD6 |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
If it's the same as the BMW 4.4 V8 , if you are relying on the belt tension to stop the pulley moving , it will likely slip. You need a second bar to hold the pulley in place. |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Should have said its a td6 but your right the pully moved slowly, and i have heard that you can shock the nut loose |
Same thing happened with mine, spent ages trying to shock it hoping the belt would hold it just enough. Had to buy a cheap 2 bar kit from eBay to hold the pulley. If you have a bit of flat bar and and drill a couple of holes you can achieve the same thing. |
Makes sense, I've stopped for the day until another fan spanner arrives tomorrow. Beer o clock now!
You really need to buy another thin spanner that goes onto a "nut" behind the viscous pulley with the arm resting on the top of the crankshaft vibration damper. One tap will shift it then.
Thanks be good to know of the correct tool.
Basically a flat bit of bar with two holes. They slot over two of the four bolts on the pulley and stop it slipping as you use the 32mm spanner on the viscous nut. |
This is the one I bought to lock the shaft, worked really well. eBay item...... eBay Item No. 333434654711 |
He makes that look easy! Thanks very helpful |
Thanks |
Can I just say you don't need to disconnect any water hoses on the TD 6 to undo the viscous fan.
Thanks Nice day! Good tips, i have the spanners now but its 30 degrees in my garage and i isn't dicking about with-it today lol. Im hot just thinking about it.
Note: TD6 only - cool running engine!
Thanks Joe, May well try that. |
