Home > Maintenance & Mods (L322) > Viscous fan removal TD6 |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 |
If it's the same as the BMW 4.4 V8 , if you are relying on the belt tension to stop the pulley moving , it will likely slip. You need a second bar to hold the pulley in place. |
6th Aug 2020 3:48pm |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
Should have said its a td6 but your right the pully moved slowly, and i have heard that you can shock the nut loose |
6th Aug 2020 3:50pm |
Same thing happened with mine, spent ages trying to shock it hoping the belt would hold it just enough. Had to buy a cheap 2 bar kit from eBay to hold the pulley. If you have a bit of flat bar and and drill a couple of holes you can achieve the same thing. |
6th Aug 2020 4:18pm |
Makes sense, I've stopped for the day until another fan spanner arrives tomorrow. Beer o clock now!
6th Aug 2020 4:32pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3971 |
You really need to buy another thin spanner that goes onto a "nut" behind the viscous pulley with the arm resting on the top of the crankshaft vibration damper. One tap will shift it then.
6th Aug 2020 4:33pm |
Thanks be good to know of the correct tool.
6th Aug 2020 4:37pm |
Basically a flat bit of bar with two holes. They slot over two of the four bolts on the pulley and stop it slipping as you use the 32mm spanner on the viscous nut. |
6th Aug 2020 4:39pm |
This is the one I bought to lock the shaft, worked really well. eBay item...... eBay Item No. 333434654711
He makes that look easy! Thanks very helpful |
6th Aug 2020 4:43pm |
Thanks |
6th Aug 2020 4:45pm |
Can I just say you don't need to disconnect any water hoses on the TD 6 to undo the viscous fan.
6th Aug 2020 4:56pm |
Thanks Nice day! Good tips, i have the spanners now but its 30 degrees in my garage and i isn't dicking about with-it today lol. Im hot just thinking about it.
8th Aug 2020 11:01am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Note: TD6 only - cool running engine!
8th Aug 2020 11:18am |
Thanks Joe, May well try that. |
8th Aug 2020 11:22am |
