Home > Maintenance & Mods (L405) > I may have a go myself but not sure what I will need.
notanrdx
United States 2017 Range Rover TDV6 Fuji White
I'm doubtful the issue is with the amp or speakers.
I'm holding out hope for a menu option.
Have you checked under the seats for a disconnected harness from the floor to the seat? My thought is if for some reason they pulled the seats to clean the carpet, perhaps they missed reconnecting?
Post #562445 23rd Jul 2020 7:25pm
mjdronfield
Might be worth buying a cheap endoscope camera, and poking it under the seat.... not sure what you can see though.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #562446 23rd Jul 2020 7:48pm
Wilpert
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Managed to photograph this through a gap. Could that be the space where the cable should be?
Post #562450 23rd Jul 2020 8:11pm
notanrdx
Close. The green connector is for all the various Microphones. You are looking for some bigger black connectors near that green one.
You amp will look a bit different (bigger). Couldn't find a decent picture.
Post #562458 23rd Jul 2020 9:21pm
Wilpert
thanks - ive got a wrench coming later that should enable me to lift the seat.
When that is done - today or tomorrow, I will hopefully get a bit of a better look.
I dont want to do more harm than good by yanking cables about then ending up not knowing how to fix it. So its a case of take it slowly.
I will keep you posted and thanks again for your help.
Post #562518 24th Jul 2020 1:08pm
peanutbob
United Kingdom 2018 Range Rover Vogue SE SDV8 Santorini Black
Have you tried changing the audio output settings from Meridian to DTS or vice versa? I think there are 3 types but I cannot remember the third... it could be that the output setting you currently are using is not allowing multi channel surround.
It’s just a guess ...it’s rather like home cinema amps which do not always utilise the full 7.1 or 9.1 etc surround speakers if the appropriate output is not selected.
Post #562536 24th Jul 2020 6:07pm
peanutbob
Also try using a multi channel 5.1 surround dvd in the cd tray as a check and switch audio outputs from Meridian to DTS.
Post #562543 24th Jul 2020 6:29pm
Wilpert
Aaaarrrrrggggghhhh
Tried using my new torx tool. Not the right one but that’s another story.
So I’ve tried all of the audio settings, meridian, Dolby and the other one. Can’t remember what it called. Still no good.
So I’m getting to the stage where I feel I need an Audio person who knows this system to look at it.
Everybody has tried to be so helpful but without hands on I don’t think I’m going to get it sorted.
I suppose I could give in and accept it as is but I don’t want to let this beat me.
Post #562563 24th Jul 2020 8:24pm
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Have you checked if the centre speaker in the dash is working, and what audio source are you using to check if the speakers are working (did you try using a DVD with 5.1 sound as suggested)?
Information published by Meridian here states that the seat-back speakers are for centre-channel sound, so it is possible that channel simply has no decoded audio to output.
From the handbook:
Quote:
To adjust the surround sound settings:
• If Meridian Surround is available, touch the Meridian, DPLIIx, or DTS Neo:6 soft keys to select 2D surround. Select Stereo to switch 2D surround off.
• If Meridian Signature Reference is fitted, 3D surround is also available. Select the 3D surround On soft key. Touch Meridian, DPLIIz, or DTS Neo:X to activate 3D surround mode.
Note: Surround sound options are not available for certain sources where the surround sound mode is set automatically
Apologies if you've already tried this, but its not clear from previous posts what source is being used.
I've no direct experience with the reference system so its possible that I'm wrong that some audio souces don't use all the speakers .
Post #562620 25th Jul 2020 5:59pm
Wilpert
Hello fifth horseman
Thanks for your advice there.
I didn’t have a 5.1 dvd but I tried a blu ray disc and it played through all speakers except the rear of seat ones.
I’ve also used the soft keys to set the audio to 3D. There are 3 x 3 d options, meridian, Dolby and another one (forgotten the name) but in all modes these rear speakers just won’t work.
I’m thinking rather than pull out the seat, could I somehow expose the connection to the rear seat speakers by removing the seat backs?
I’m sounding a bit desperate here 😀
Post #562621 25th Jul 2020 6:09pm
Fifth Horseman
Its puzzling that it is only the seat back speakers that are not working, if it was the plug to the amplifier disconnected then the headlining speakers would not work either.
The amplifier connector you are looking for is a green 16 way one, the speakers are connected to pins 1 (brown/blue) and 9 (yellow/orange) for the left seat and 2 (brown/yellow) and 10 (grey/brown) for the right seat.
Post #562627 25th Jul 2020 7:18pm
Wilpert
Agreed, i too feel it would be a bank of speakers that wouldn’t work.
It can’t be possible that just 2 random cables could come adrift.
Thanks for the info on the speaker wire colours that might help if I go down the seat out route.
Might it be feasible that one speaker might be faulty or not properly connected within the seat and that would cause both of those to cut out ?
Post #562628 25th Jul 2020 7:25pm
Fifth Horseman
From the wiring diagram there is a connector that has both seat back speaker signals, there may be a problem with this, but I cannot find its location.
If there is an electrical fault with the speaker it should cause the amplifier module to generate a DTC code which may help to localise the fault. Unfortunately it is also possible that a fault with the speakers may have blown the output module for that channel in the amplifier.
Post #562641 25th Jul 2020 8:40pm
