![]() | Home > eBay & Bargain Spots > Mercedes Sprinter Jack, cheap on eBay |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
@RichM63 that's a good one, thank you!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8500 ![]() ![]() ![]() |
Mine maxes out at 530mm Stan, a lot more than most off the shelf ones... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3803 ![]() ![]() ![]() |
You definitely need a Jack with double piston lift.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35593 ![]() ![]() |
the best i can find is one on amazon for £29 for a 460mm lift..
Stan,
i like many others dont use the scissor jack Mike, although i did once on a salisbury plain trip but then there were 2 of us and the punctured wheel was taken off and new one on in seconds.. ... - .- -.
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
From experience I can recommend that you don’t try to lift the back end by placing the Sprinter jack in the centre of the subframe, between the exhausts. If you do this and it isn’t perfectly central, your car may attempt to do the Time Warp. Possibly a jump to the left, possibly a step to the right. Either way, a heart stopping moment |
FJ12Jagmen Member Since: 25 Jun 2020 Location: Danbury Essex Posts: 66 ![]() ![]() ![]() |
Can anyone tell me the jack height required to lift an inflated wheel off the ground?
