Home > eBay & Bargain Spots > Mercedes Sprinter Jack, cheap on eBay
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
@RichM63 that's a good one, thank you!! Thumbs Up Bow down they have the pocketmoney emptying potential
Post #562418 23rd Jul 2020 12:55pm
stan wrote:
whats the reach on these merc jacks?
i ask because machine mart have a vast array of jacks @ £30'ish and under ,
https://www.machinemart.co.uk/c/bottle-jacks/?s=pricelowhigh
Mine maxes out at 530mm Stan, a lot more than most off the shelf ones... Pete
Post #562482 24th Jul 2020 9:34am
Baltic Blue
You definitely need a Jack with double piston lift.
Half way up the second piston before a fully inflated tyre clears .
Post #562483 24th Jul 2020 9:43am
the best i can find is one on amazon for £29 for a 460mm lift..
i'm curious to know how the supplied scissor jack can extend that much
i do have a sprinter jack but i always jack on the suspension arms .. ... - .- -.
Post #562491 24th Jul 2020 10:58am
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I was shocked just how high the car needed jacking to get a wheel off the ground, the first time I used the jacking point and now use the suspension arm and it's much less dramatic. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #562492 24th Jul 2020 11:03am
Baltic Blue
Stan,
You could try the original jack , but with the wheel secure.
You will quickly learn why they are so dangerous.
The two arms of the scissor get nearly vertical .
Post #562499 24th Jul 2020 11:59am
i like many others dont use the scissor jack Mike, although i did once on a salisbury plain trip but then there were 2 of us and the punctured wheel was taken off and new one on in seconds.. ... - .- -.
Post #562500 24th Jul 2020 12:04pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
From experience I can recommend that you don’t try to lift the back end by placing the Sprinter jack in the centre of the subframe, between the exhausts. If you do this and it isn’t perfectly central, your car may attempt to do the Time Warp. Possibly a jump to the left, possibly a step to the right. Either way, a heart stopping moment Shocked 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #562554 24th Jul 2020 8:40pm
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Can anyone tell me the jack height required to lift an inflated wheel off the ground?
I should have measured it last time but was busy with a small child who walked underneath at the time. Shockingly high Surprised
Could measure the child i suppose...
Post #562757 26th Jul 2020 9:24pm
