Home > Technical (L405) > 2014 RRL405 needs coolant every week
DNZFLS007
United States 2014 Range Rover HSE 3.0 SC V6 Santorini Black
Bow down Bow down Hello My Rover family i have a 2014 RR L405 V6 SUPERCHARGED. My truck isn't running hot and I don't see any leaks....but it is running low on coolant once a week. I have 114,000 on the dash...no checking engine lights on but i am concerned to find out is this normal ..I do live in hot ass houston....need help, what could be the issue.
Post #560103 3rd Jul 2020 3:08pm
Not a common engine in these parts I’m afraid, you may even be the only one on here with one.
As you’ve probably figured it shouldn’t be losing coolant. Has it had it changed recently? Has anyone been at the system for any reason and it need properly bleeding, which if not done properly will keep pulling coolant out of the Header tank until it’s happy...
If it’s not been messed with then it has got a leak. And by the sound of it quite a big one.... There is nothing that can't be fixed with a hammer😜😜
Post #560280 5th Jul 2020 8:41am
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
If there are no visible leaks then it might be the head gasket. A failed head gasket will usually give a white exhaust. ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #561866 18th Jul 2020 6:02am
qwerty
2016 Range Rover Autobiography SDV8 Carpathian Grey
A friend had the same issue on his 5.0 sc and it was the water pump, replaced and now fixed. Not very visable signs of a leak but careful inspection showed markings below the pump area. Thumbs Up
Post #561870 18th Jul 2020 6:57am
DNZFLS007
Yes I'm responding 125,000 miles later....the Rover is running good and it was the water pump......no problems since...thank you
Post #590477 6th Apr 2021 3:48pm
qwerty
Good to hear. Thumbs Up
Post #590647 8th Apr 2021 7:47am
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
I have a 2014 3.0l since new and now it is drinking water. I have found out that the rear offside (UK car) there is a set of hoses that send coolant to the rear heating system and these have a leak. This is going to set me back £2000 to have the pipes replaced due to the rear sub frame will need to be lowered to gain access.
Since you are in a hot climate is the water evaporating before you see it?
Just passing on my finds from my car.
3.0 14M5 Autobiography
Post #590674 8th Apr 2021 5:56pm
