Home > Technical (L322) > p244b-68 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3143 |
Definition of error code P244B - Diesel Particulate Filter Differential Pressure Too High“
2nd Jul 2020 6:14pm |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
What's the normal level before regen? Mine seems to kick in at about 21.9.
2nd Jul 2020 7:10pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Make sure it’s a high pressure test
2nd Jul 2020 7:18pm |
no "normal" level. Can kick in any time but my warning light (yellow) came on at 23.5g. I had a passive regeneration yesterday at 9.6 (down to 8.2)
2nd Jul 2020 7:27pm |
I will have to check the pressure. I was reading the Jaguar tsb last night for the dpf codes and saw it was asking that.
2nd Jul 2020 7:35pm |
Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd Jul 2020 7:41pm |
My IID only has the inferred field for soot which is what I use. The screen shot is my standard set up for monitoring Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd Jul 2020 7:42pm |
Oil quality dilution should be no more than 7 iirc from Dolphinboy Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd Jul 2020 7:44pm |
Have you got the thicker silicones hoses fitted into the intake?
2nd Jul 2020 7:47pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Regen should kick in at 17.5g if fuel + speed + etc criteria are met Cheers, Greg
2nd Jul 2020 8:18pm |
yes it's a calculated figure, the algorithm(s) are quite complicated but actually found to be quite accurate. Loads of info in my 'what to do if your DPF is full' guide in the wiki section . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
2nd Jul 2020 8:21pm |
I will check oil factor. New silicone hoses are installed and I have checked fit and for oil/soot.
2nd Jul 2020 8:40pm |
Sounds like it's behaving normally to me. Have you had an amber DPF light? If not, then probably nothing is wrong Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Jul 2020 7:22am |
I've noticed this too after it's done a burn down to around 2 or 3g...in the end I stopped monitoring using the IID to save my sanity Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
3rd Jul 2020 7:26am |
