Home > Technical (L322) > p244b-68
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
p244b-68
Keep getting the above code along with P040.
Just changed the intake elbow with new. Hose all appear to be fine too. Any ideas of other checks?
Soot levels go up pretty quick. They remain stable when running longer journeys and passive regen is working. But shoot up really quickly at low speeds. 2011 4.4tdv8 Vogue
Baltic Blue
Post #559972 2nd Jul 2020 4:46pm
Dolphinboy
Definition of error code P244B - Diesel Particulate Filter Differential Pressure Too High“
Means Your Dpf is filling up. Could well be an air leak (4 hoses to plenum, air inlet manifold etc)
Get a high pressure smoke test done. Thumbs Up
Post #559986 2nd Jul 2020 6:14pm
Gazcw
What's the normal level before regen? Mine seems to kick in at about 21.9.
I will get a smoke test done. 2011 4.4tdv8 Vogue
Baltic Blue
Post #559993 2nd Jul 2020 7:10pm
DrRob
Make sure it’s a high pressure test
What’s the Particulate filter differential pressure sensor voltage show? Should be around 0.7V Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #559995 2nd Jul 2020 7:18pm
Dolphinboy
no "normal" level. Can kick in any time but my warning light (yellow) came on at 23.5g. I had a passive regeneration yesterday at 9.6 (down to 8.2)
Be aware you cannot do a MD forced Regen past 28.5g.
Post #559998 2nd Jul 2020 7:27pm
Gazcw
I will have to check the pressure. I was reading the Jaguar tsb last night for the dpf codes and saw it was asking that.
My passive regens seem to hold the levels or reduce very slightly by 0.1 or 2. Active drops to about 4 and stops. It then climbs rapidly within 30 seconds to around 7 or 8 which I thought was weird.
I cannot get the soot mass other than by the inferred using differential pressure so not sure how accurate the figures are. My iid cannot be seen on a pc so I cannot update it. 2011 4.4tdv8 Vogue
Baltic Blue
Post #560000 2nd Jul 2020 7:35pm
DrRob
Post #560002 2nd Jul 2020 7:41pm
DrRob
My IID only has the inferred field for soot which is what I use. The screen shot is my standard set up for monitoring Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560003 2nd Jul 2020 7:42pm
DrRob
Oil quality dilution should be no more than 7 iirc from Dolphinboy Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560004 2nd Jul 2020 7:44pm
DrRob
Have you got the thicker silicones hoses fitted into the intake?
Post #560005 2nd Jul 2020 7:47pm
GGDR
Regen should kick in at 17.5g if fuel + speed + etc criteria are met Cheers, Greg
Post #560010 2nd Jul 2020 8:18pm
GGDR
yes it's a calculated figure, the algorithm(s) are quite complicated but actually found to be quite accurate. Loads of info in my 'what to do if your DPF is full' guide in the wiki section
. Cheers, Greg
Post #560011 2nd Jul 2020 8:21pm
Gazcw
I will check oil factor. New silicone hoses are installed and I have checked fit and for oil/soot.
I went out for a long drive after clearing faults. I got a passive regen and it sat at 18.1. Went to shop and switched back on. Soot had gone to 20.9. Got it up to 50 and planned to get to A14. Regen started just under 22, had to slow for a roundabout not stop but the regen stopped at 10.5. Got to A14 and it sat at 350 degrees doing passive and held it at 11.1. 2011 4.4tdv8 Vogue
Baltic Blue
Post #560018 2nd Jul 2020 8:40pm
DrRob
Sounds like it's behaving normally to me. Have you had an amber DPF light? If not, then probably nothing is wrong Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560047 3rd Jul 2020 7:22am
DrRob
Re: p244b-68
I've noticed this too after it's done a burn down to around 2 or 3g...in the end I stopped monitoring using the IID to save my sanity Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560049 3rd Jul 2020 7:26am
