Home > Technical (L322) > LR L322 2010 easy entry exit - only wheel working
sergeiicz
Czech Republic 2002 Range Rover HSE Td6 Epsom Green
Hello is there any way how to reset/set easy entry exit function? Mine is working only with steering wheel lifting, but seats doesnt move a bit (i am not at lowest position for sure)
- electric. positioning is function on both seats so no problem here
thank you
Post #559914 2nd Jul 2020 1:37pm
mjdronfield
I don’t believe the seat moves, only the steering wheel.
The seat moves if the user of the other car key sets it to a different memory position.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #559951 2nd Jul 2020 4:26pm
sergeiicz
mine seats moving before everytime with steering wheel to the lowest position ... is it possible that this has been coded before?
i was at service with daylight running lights coding (no success Smile ) so they must reboot or recode ECU and after that only steering wheel moving
Post #559963 2nd Jul 2020 5:08pm
Why don't you back track and reverse any CCF changes and see if the easy entry seat movement comes back... Then try CCF's again one by one... Thumbs Up
If your playing with an IID then there is the "revert to factory CCF configuration" and start again Thumbs Up
Post #559971 2nd Jul 2020 5:44pm
sergeiicz
'cause i have no IID tool (thats why i've been at service with DRL coding ...)
Post #559976 2nd Jul 2020 6:03pm
Nick591
With the key in and ignition on set the seat and wheel to where you want it, then press the M button on the side of the seat followed by one of the numbers 1, 2 or 3. Then when you use your key the seat and wheel should move to the set position. Easy entry/exit only moves the wheel up to the max height when you turn ign off and down to set height when you turn it on. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #559991 2nd Jul 2020 7:52pm
sergeiicz
i know i know ... but i am 100% sure that with Easy e/e it moves with steering wheel to highest and seat to lowest position, but after some coding/flashing my ECU due to DRL it only moves with steering wheel now .. if its not a standard option i will ask them to check for this in my backup ECU file
thank you
Post #560014 2nd Jul 2020 9:29pm
Weegie
My understanding is, that if you are using the same key with easy entry programmed as per Nick591, only the wheel moves. If another key is used, which is programmed to another memory and it is different from the last key used then tbe seats will move to the memory position.
If you have two keys you could check if that is the case John
GAP iiD BT-Sold
Post #560016 2nd Jul 2020 9:35pm
sergeiicz
Weegie good point, but iam using only one key since i bought that car Wink but will try just to be sure ...
as far as i know easy entry should move driver's seat to lowest position - as i am not a very tall man and having my seat quite high i want that function back because i dont want to wear off my seat quicker Smile
Post #560019 2nd Jul 2020 9:57pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Both my wheel and seat move. I only use one key.
Post #560020 2nd Jul 2020 10:11pm
RJDS
United Kingdom 2011 Range Rover Autobiography TDV8 Bournville
Both my seat and wheel move on both keys. 2011 TDV8 4.4 AB Bournville Brown
Post #560074 3rd Jul 2020 11:57am
Then take it back as the coding has changed more than just the DRL setting sir...
Post #560081 3rd Jul 2020 12:10pm
sergeiicz
yeah, they told me as there was an error with downloading DRL "function" to my ECU it should be some glitch too, will see after i manage to get there Smile
Post #560087 3rd Jul 2020 1:35pm
sergeiicz
- just a quick update -
did a seat calibration via SDD, set one position to memory and now works both fine
Post #562012 19th Jul 2020 12:45am
Thumbs Up Glad you got it sorted sir... Thumbs Up
Post #562017 19th Jul 2020 1:41am
