![]() | Home > Technical (L322) > LR L322 2010 easy entry exit - only wheel working |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7896 ![]() ![]() ![]() |
I don’t believe the seat moves, only the steering wheel.
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 ![]() ![]() ![]() |
mine seats moving before everytime with steering wheel to the lowest position ... is it possible that this has been coded before?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Why don't you back track and reverse any CCF changes and see if the easy entry seat movement comes back... Then try CCF's again one by one... |
'cause i have no IID tool (thats why i've been at service with DRL coding ...) |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
With the key in and ignition on set the seat and wheel to where you want it, then press the M button on the side of the seat followed by one of the numbers 1, 2 or 3. Then when you use your key the seat and wheel should move to the set position. Easy entry/exit only moves the wheel up to the max height when you turn ign off and down to set height when you turn it on. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
i know i know ... but i am 100% sure that with Easy e/e it moves with steering wheel to highest and seat to lowest position, but after some coding/flashing my ECU due to DRL it only moves with steering wheel now .. if its not a standard option i will ask them to check for this in my backup ECU file
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
My understanding is, that if you are using the same key with easy entry programmed as per Nick591, only the wheel moves. If another key is used, which is programmed to another memory and it is different from the last key used then tbe seats will move to the memory position.
Weegie good point, but iam using only one key since i bought that car |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Both my wheel and seat move. I only use one key. |
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 49 ![]() ![]() ![]() |
Both my seat and wheel move on both keys. 2011 TDV8 4.4 AB Bournville Brown |
Then take it back as the coding has changed more than just the DRL setting sir... |
yeah, they told me as there was an error with downloading DRL "function" to my ECU it should be some glitch too, will see after i manage to get there |
- just a quick update -
