Home > Technical (L405) > Turbo Actuator Problem SDV8 |
basmaignee Member Since: 07 Jun 2020 Location: Mayenne Posts: 5 |
Hello all I am new here and Experiencing a problem with the primary turbo on my 2013 SDV8.
8th Jun 2020 4:43pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
Do a search,
8th Jun 2020 5:00pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
A split hose? |
9th Jun 2020 12:24am |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 |
I think you are right Cam Tech Craig I had a split turbo hose made a terrible sucking sound on boost plus a drop in power. |
9th Jun 2020 5:44am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1773 |
What fault codes are actually stored on the car? |
9th Jun 2020 6:50am |
Thank you for the replies, the actuator is holding the VGT open constantly and this is the reason for the noise, when the actuator is disconnected the noise goes away. I’ve physically inspected the whole system and there are no air leaks. I’m going to go with electrical is the issue as the actuator can’t communicate with the car. There are no fault codes stored. Turbo Rod which connects to the actuator moves freely without any interference so that’s a good sign? |
9th Jun 2020 9:22am |
Basmaignee,
9th Jun 2020 10:07am |
Thank you BB, I had a very intense search when you mentioned it but couldn’t find anything. I will have a look on Topix, and I’ve been looking at the wiring diagrams. Will have a play today and see what I can come up with! Thanks alot |
9th Jun 2020 10:16am |
https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf |
9th Jun 2020 11:16am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
I wonder if this thread is any help. It is pretty long but on page 8 Red Merle posted a solution to the problem he had. May not be relevant but you can look.
9th Jun 2020 11:18am |
Thank you for the very helpful links, if i cant get any joy out of it i will run it to a local dealer! |
9th Jun 2020 12:05pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8603 |
Unfortunately I think the fix above is a preventative measure. If it is what is wrong with yours, fingers crossed not, then fixing it once it has happened isn’t as straightforward as the TSB. There is nothing that can't be fixed with a hammer😜😜
10th Jun 2020 4:42pm |
Problem Solved, horrendous amount of play in the turbo. Currently in the process of changing it myself without lifting the body. See how this goes... |
24th Jun 2020 9:02am |
rlr73 Member Since: 20 May 2023 Location: Bristol Posts: 1 |
Hello, sorry to resurrect an old thread but did you manage to change it yrself without removing motor?
20th May 2023 2:11pm |
