Home > Technical (L405) > Turbo Actuator Problem SDV8
basmaignee
France 2013 Range Rover Vogue SDV8 Santorini Black
Hello all I am new here and Experiencing a problem with the primary turbo on my 2013 SDV8.
When I purchased the car this year in mid January it was fabulous with no issues, recently i have noticed a noise on the drivers side primary turbo, abit like a hoover noise. both turbos had been changed before i purchased the car so I am wondering what it could be, no fault codes come up but on my ICARSOFT data it says Boost Pressure Actuator Bank 1 measured positioned is Unknown/Invalid. since then i have changed the actuator but it has changed nothing. Any help would be greatly appreciated!
sorry if the image is sideways!
Post #556945 8th Jun 2020 4:43pm
Baltic Blue
Do a search,
I have read something on here about oil contamination on the wiring.
Possibly associated with the oil level sensor.
I seem to remember a technical bulletin referred to., but I don’t recall details because it refers to L405’s.
Post #556949 8th Jun 2020 5:00pm
BB you are correct, there is a TSB relating to the oil sensor wiring, which then affect the turbo operation. It was down as an outstanding alert on the online service history, but has now disappeared. There is nothing that can't be fixed with a hammer😜😜
Post #556954 8th Jun 2020 6:12pm
A split hose?
Post #557007 9th Jun 2020 12:24am
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
I think you are right Cam Tech Craig I had a split turbo hose made a terrible sucking sound on boost plus a drop in power.
Post #557008 9th Jun 2020 5:44am
Mikey
What fault codes are actually stored on the car?
Post #557011 9th Jun 2020 6:50am
basmaignee
Thank you for the replies, the actuator is holding the VGT open constantly and this is the reason for the noise, when the actuator is disconnected the noise goes away. I’ve physically inspected the whole system and there are no air leaks. I’m going to go with electrical is the issue as the actuator can’t communicate with the car. There are no fault codes stored. Turbo Rod which connects to the actuator moves freely without any interference so that’s a good sign?
Post #557044 9th Jun 2020 9:22am
Baltic Blue
Basmaignee,
I have been doing a search of the site, because I know I have read a thread detailing exactly the same symptoms as yours.
Unfortunately I can’t find it but , basically it referred to oil seeping up the wiring loom and giving problems with turbo actuation.
It definitely referred to a fix in a TSB.
You could either try Topix or contact a dealer to get full details, or just hope the original poster reads this thread and gives you a link to the post.
Post #557049 9th Jun 2020 10:07am
basmaignee
Thank you BB, I had a very intense search when you mentioned it but couldn’t find anything. I will have a look on Topix, and I’ve been looking at the wiring diagrams. Will have a play today and see what I can come up with! Thanks alot
Post #557050 9th Jun 2020 10:16am
Mikey
https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf
Post #557058 9th Jun 2020 11:16am
Weegie
I wonder if this thread is any help. It is pretty long but on page 8 Red Merle posted a solution to the problem he had. May not be relevant but you can look.
https://www.fullfatrr.com/forum/topic48181...;start=105
Red Merle may be along to contribute.
Good luck
PS. Just seen Mikey's post. Thumbs Up John
GAP iiD BT
Post #557060 9th Jun 2020 11:18am
basmaignee
Thank you for the very helpful links, if i cant get any joy out of it i will run it to a local dealer!
Post #557067 9th Jun 2020 12:05pm
Unfortunately I think the fix above is a preventative measure. If it is what is wrong with yours, fingers crossed not, then fixing it once it has happened isn’t as straightforward as the TSB. There is nothing that can't be fixed with a hammer😜😜
Post #557212 10th Jun 2020 4:42pm
basmaignee
Problem Solved, horrendous amount of play in the turbo. Currently in the process of changing it myself without lifting the body. See how this goes...
Post #558816 24th Jun 2020 9:02am
rlr73
Hello, sorry to resurrect an old thread but did you manage to change it yrself without removing motor?
Thanks
Post #664545 20th May 2023 2:11pm
