![]() | Home > Maintenance & Mods (L322) > Sill repair/fabrication in beds/herts/essex ? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Excellent news! Sorry, I wasn't sure if you were going to do it or not. Brilliant news! A lot of L322 owners will thank you if YRM start making them ![]() ![]() ![]() ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Did you find a bodyshop in the end to cut it all out? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 ![]() ![]() ![]() |
Yea, the pictures are all on the second page of this thread, some of it has been left on as they didn't want to cut out too much, they will worry about the finer details later on. |
That is a very good question.........some of it is surface rust, some will need chopping out and replacing with made up sections. But there is an update, so i'll be posting after this one. |
So a little update for where we are.
The whole sections obviously wont be fitted to the car as the breaker cut out right up to the rear door latch, but as it includes the inner panels as well, i'll have a chat with my garage to see what is best regarding re fitment, then it'll be off to the bodyshop for some paint. Ill get a few dings and items painted whilst i'm there (depending on cost) I will contact Ronnie tomorrow to state that I have managed to find these sills and arch panels and see what he can do about stocking these on their web site or contact methods etc. He has all my measurements and profile heights for the rear sill panels. As mentioned earlier on, they are unable to fabricate the pressed arch panels due to cost. This is just one of many pictures and measurements that was sent to YRM, so you know what would be manufacturered.
Hopefully this will start off a manufacturing process for the rear sill panels for an L322 ![]() |
rr4tq Member Since: 03 Jul 2019 Location: California Posts: 9 ![]() ![]() |
Curious why you didn't consider cutting a larger piece from the donor vehicle? I see you had rust bubble at the rear towards the bumper. It's sort of funny but I think we are rust twins...our issues look identical. |
But I did ??? - I dont need all that section, hence why I asked to for more than I needed.
Good progress |
GraemeJudge Member Since: 10 Feb 2018 Location: Fareham Posts: 54 ![]() ![]() |
Nice to hear you have a solution for yours but i hope that they still do start to make the sills as I am very interested in some look for your update when you let them know cheers. |
It really shocked me when I discovered the amount of corrosion existed on the L322, I mean, it is a modern Land Rover and not THAT old. Anyway, I am looking forward to see the results of your repair. By the way, how does your rear subframe/suspension bits look in terms of rust? Mine has some surface rust from what I can see but I wonder what I'll find if I look hard...? |
Right, little update...the welding is done !!
And what was left from the bits I gave them (if anyone wants wants left give me a shout - both sides lol)
Its booked in at the bodyshop next week for the rest, price agreed and a mop of the whole car so should shave 10 years off the old girl I hope !! ![]() I have spent 3 hours a night the past 2 nights scraping off as much surface rust as I can from the underside of the vehicle (front to back). It wasn't pretty, thank the lord for goggles and comma black underseal. Makes me think if this was done at 100.000 or with some other non coloured special oils via a land rover service bulletin a lot of L322's out there would be in much better condition than they are at the moment Results below
They also re-added the strengthening metal/welding to allow the car to be lifted from the rear again via the sill grommets (still think ill only ever trust lifting it via door open, with the wheels on on those even the front ones). If it gets lifted with the wheels off and the door open, ill be jacking it on the leg braces etc[/list] |
Rear subframe and suspension bits.........in a word not good. Don't look !! - you'll feel much better for it. As much scraping off as I could be bothered to do, and that was a lot !! Interesting you mention that, as i've posted an update about that area too (above this reply) |
I may have an opportunity to purchase a dead but complete L322 with zero rust for VERY cheap. It would be a good donor vehicle for me to cut the panels and maybe even swap the entire rear subframe over...gives me a headache just thinking about it though... |
Hey guys
Its unfortunate I wasn't able to get any sills made up in the end, I really had hoped that my measurements would have worked out as a blueprint for others for a box section for the inner/outer sills, but then it wasn't meant to be. It could have easily have wrote off the vehicle if it didn't pass its next MOT and instead of it being what it is now, I would have had to have broke it. Same place I was able to get the sills from, I got myself a new steering wheel for £50 that looks brand new after a clean up *Fitted after negative lead left off for 20 mins, no power to the car.
Shes come a long way since dragging it back on a trailer I rented
