![]() | Home > Maintenance & Mods (L322) > Sill repair/fabrication in beds/herts/essex ? |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Excellent news! Sorry, I wasn't sure if you were going to do it or not. Brilliant news! A lot of L322 owners will thank you if YRM start making them ![]() ![]() ![]() ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Did you find a bodyshop in the end to cut it all out? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 ![]() ![]() ![]() |
Yea, the pictures are all on the second page of this thread, some of it has been left on as they didn't want to cut out too much, they will worry about the finer details later on. |
That is a very good question.........some of it is surface rust, some will need chopping out and replacing with made up sections. But there is an update, so i'll be posting after this one. |
So a little update for where we are.
rr4tq Member Since: 03 Jul 2019 Location: California Posts: 9 ![]() ![]() |
Curious why you didn't consider cutting a larger piece from the donor vehicle? I see you had rust bubble at the rear towards the bumper. It's sort of funny but I think we are rust twins...our issues look identical. |
But I did ??? - I dont need all that section, hence why I asked to for more than I needed.
Good progress |
GraemeJudge Member Since: 10 Feb 2018 Location: Fareham Posts: 54 ![]() ![]() |
Nice to hear you have a solution for yours but i hope that they still do start to make the sills as I am very interested in some look for your update when you let them know cheers. |
It really shocked me when I discovered the amount of corrosion existed on the L322, I mean, it is a modern Land Rover and not THAT old. Anyway, I am looking forward to see the results of your repair. By the way, how does your rear subframe/suspension bits look in terms of rust? Mine has some surface rust from what I can see but I wonder what I'll find if I look hard...? |
Right, little update...the welding is done !!
Rear subframe and suspension bits.........in a word not good. Don't look !! - you'll feel much better for it. As much scraping off as I could be bothered to do, and that was a lot !! Interesting you mention that, as i've posted an update about that area too (above this reply) |
I may have an opportunity to purchase a dead but complete L322 with zero rust for VERY cheap. It would be a good donor vehicle for me to cut the panels and maybe even swap the entire rear subframe over...gives me a headache just thinking about it though... |
Hey guys
