![]() | Home > Maintenance & Mods (L322) > 2011 brake pad wear warning light |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35527 ![]() ![]() |
did you replace the brake pad wear indicator sensor? ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
The wiring to the sensors get very brittle and thus very easily broken, but I am not sure if a broken wire gives a permanent alarm or just stops the warning working when the pads wear down, sorry I can’t remember.
naylorm79 Member Since: 17 Mar 2020 Location: Manchester Posts: 9 ![]() ![]() ![]() |
Hi,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
As above. They work on open circuit so if the wires are broken they don't show a fault but would not be working. If both are broken and touch or they short to ground they will show a fault.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2579 ![]() ![]() ![]() |
The warning light works by part of the sensor being worn away breaking the connection between the 2 wires. Hence once the warning light comes on the sensor is worn-out. Cutting off the sensor and joining the wires together stops the warning light occurring. |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Advance warning, the rear ones are a pig to replace. Easiest to remove the inner liner, but doable with some patience when just undoing a bolt or two. Mine didn’t have the wire at all, so someone took a shortcut |
