Home > Maintenance & Mods (L322) > 2011 brake pad wear warning light
Morris
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
Warning light came on, checked and replaced pads but warning light remains on... Any ideas?
Post #552502 3rd May 2020 9:08am
did you replace the brake pad wear indicator sensor? ... - .- -.
Post #552503 3rd May 2020 9:14am
Baltic Blue
The wiring to the sensors get very brittle and thus very easily broken, but I am not sure if a broken wire gives a permanent alarm or just stops the warning working when the pads wear down, sorry I can’t remember.
Post #552521 3rd May 2020 11:37am
naylorm79
United Kingdom 2010 Range Rover Vogue TDV8 Bonatti Grey
Hi,
As Baltic Blue says the wires get very brittle, it happened to my rear sensor. Once the sensor wires touch you need to replace the sensor for a new one.
Post #552608 4th May 2020 10:21am
Weegie
As above. They work on open circuit so if the wires are broken they don't show a fault but would not be working. If both are broken and touch or they short to ground they will show a fault.
For the cost I would always renew. John
GAP iiD BT
Post #552609 4th May 2020 10:34am
GraemeS
The warning light works by part of the sensor being worn away breaking the connection between the 2 wires. Hence once the warning light comes on the sensor is worn-out. Cutting off the sensor and joining the wires together stops the warning light occurring.
Post #552625 4th May 2020 11:47am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Advance warning, the rear ones are a pig to replace. Easiest to remove the inner liner, but doable with some patience when just undoing a bolt or two. Mine didn’t have the wire at all, so someone took a shortcut Wink
But yes, always replace the wire. It’s on the drivers side iirc in the U.K.
Post #553246 9th May 2020 1:00pm
