![]() | Home > Technical (L322) > RED TRIANGLE Warning: Restricted Performance |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
I know I lot less about these cars compared to others on here, but, this happened to me the other day & was due to hitting 3000rpm on a 'spirited emergence from a roundabout onto a main road' I needed some oooomph & by golly she had it......but then I got the message RP. The L322 TDV8 runs sequential turbos (not sure about yours) & it's possible the second turbo actuator got stuck?
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
There's lots on here ref Restricted performance (RP). Search is your friend.
RR1234 Member Since: 29 Apr 2013 Location: Northern Ireland Posts: 55 ![]() ![]() |
Thank you so much for your reply and thoughts. In short; I locked the car, walked away and came back in 30 mins. All appears to be fine. I took it around the block to see if anything changed but it appears to be okay. I'll let you know if it re-occurs.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
16,000 miles |
So, is there a chance you gave her 'the big 'un' in the right foot department like I did?
They do seem to appreciate the occasional Italian tune up rather than constant gentle treatment - or at least that';s what I keep telling myself |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Alistair, its the race away from the toll booths at full (mapped) chat! Smug as you have a TAG |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
TAGs rule |
Thanks for the notes everyone. I'll report back in 5,000 miles! |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Whats's a TAG ?
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Used to be a transponder for Tolls such as the Dartford Crossing. Now replaced with an account & ANPR. May still be in use though at some sites. 2003 Range Rover Vogue TD6 |
Telepeage tags for the french autoroutes |
@op.
