Home > Technical (L322) > RED TRIANGLE Warning: Restricted Performance |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 682 |
I know I lot less about these cars compared to others on here, but, this happened to me the other day & was due to hitting 3000rpm on a 'spirited emergence from a roundabout onto a main road' I needed some oooomph & by golly she had it......but then I got the message RP. The L322 TDV8 runs sequential turbos (not sure about yours) & it's possible the second turbo actuator got stuck?
16th Apr 2020 3:04pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
There's lots on here ref Restricted performance (RP). Search is your friend.
16th Apr 2020 3:16pm |
RR1234 Member Since: 29 Apr 2013 Location: Northern Ireland Posts: 55 |
Thank you so much for your reply and thoughts. In short; I locked the car, walked away and came back in 30 mins. All appears to be fine. I took it around the block to see if anything changed but it appears to be okay. I'll let you know if it re-occurs.
16th Apr 2020 7:13pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7921 |
16,000 miles
16th Apr 2020 7:34pm |
So, is there a chance you gave her 'the big 'un' in the right foot department like I did?
16th Apr 2020 7:39pm |
They do seem to appreciate the occasional Italian tune up rather than constant gentle treatment - or at least that';s what I keep telling myself |
16th Apr 2020 7:47pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Alistair, its the race away from the toll booths at full (mapped) chat! Smug as you have a TAG |
16th Apr 2020 8:33pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
TAGs rule
16th Apr 2020 9:16pm |
Thanks for the notes everyone. I'll report back in 5,000 miles! |
16th Apr 2020 9:22pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Whats's a TAG ?
16th Apr 2020 10:00pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Used to be a transponder for Tolls such as the Dartford Crossing. Now replaced with an account & ANPR. May still be in use though at some sites. 2003 Range Rover Vogue TD6 |
16th Apr 2020 11:18pm |
Telepeage tags for the french autoroutes
17th Apr 2020 5:25am |
Cheers, Greg
17th Apr 2020 6:19am |
@op.
17th Apr 2020 9:58am |
