![]() | Home > Technical (L405) > What is this cable and connector ? |
Historian Member Since: 16 Mar 2019 Location: Lancashire Posts: 33 ![]() ![]() |
It's for the 'transit relay'- stops the battery going flat between initial build and delivery to the dealer. Removed as part of PDI and the loose connector just tucked away. Same can be found on all Jaguars too. |
SCL Member Since: 10 Jul 2017 Location: West Midlands Posts: 50 ![]() ![]() ![]() |
Historian, many thanks for your reply, very much appreciated. You can't swim uphill in custard all the time, sometimes you just have to go with the flow. |
basil Member Since: 09 Dec 2014 Location: UK Posts: 88 ![]() ![]() |
So can this be used as a charging point? |
Absolutely no idea if it can be used as a charging point, but would doubt it. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
It is supposed to tuck into a little pocket in the polystyrene round the compressor. Just to the right of the compressor there should be a small hole in the top of the poly which looks the right size for the plug. It goes in there.ππ» There is nothing that can't be fixed with a hammerππ
Time to get the spare wheel out again then and put the connector in its proper home rather than just leaving it dangle. You can't swim uphill in custard all the time, sometimes you just have to go with the flow. |
