Home > Technical (L405) > What is this cable and connector ?
SCL
England 2015 Range Rover Autobiography SDV8 Causeway Grey
I was checking the battery in the boot and found this cable and connector. It is to the right of the battery as you look from the rear of the car. It is not plugged into anything. Does it look like an original build time specification or an after market addition?
I did have a new battery fitted 15 months ago by LR Assist. Did they forget to reattach the connector?
 You can't swim uphill in custard all the time, sometimes you just have to go with the flow.
Post #549941 11th Apr 2020 9:06am
Historian
It's for the 'transit relay'- stops the battery going flat between initial build and delivery to the dealer. Removed as part of PDI and the loose connector just tucked away. Same can be found on all Jaguars too.
Post #550030 11th Apr 2020 9:28pm
SCL
Historian, many thanks for your reply, very much appreciated. You can't swim uphill in custard all the time, sometimes you just have to go with the flow.
Post #550036 11th Apr 2020 10:13pm
basil
2014 Range Rover Autobiography 5.0 SC V8 Mariana Black
So can this be used as a charging point?
Post #550039 11th Apr 2020 10:28pm
Historian
Absolutely no idea if it can be used as a charging point, but would doubt it.
Post #550040 11th Apr 2020 10:30pm
It is supposed to tuck into a little pocket in the polystyrene round the compressor. Just to the right of the compressor there should be a small hole in the top of the poly which looks the right size for the plug. It goes in there.πŸ‘πŸ» There is nothing that can't be fixed with a hammer😜😜
Post #550127 12th Apr 2020 6:32pm
SCL
Time to get the spare wheel out again then and put the connector in its proper home rather than just leaving it dangle. You can't swim uphill in custard all the time, sometimes you just have to go with the flow.
Post #550128 12th Apr 2020 6:46pm
