![]() | Home > Maintenance & Mods (L405) > N375 - engine oil level sensor wiring harness installation |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3803 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic54721.html
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2638 ![]() ![]() |
The original harness has a habit of migrating oil from the sump into the primary turbo's electronics, often if not always requiring a new turbo as well as the harness being replaced with the later design.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1800 ![]() ![]() |
https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 ![]() ![]() ![]() |
Thanks for the replies - wonder if it’s coincidence that there are campaigns under N375 and N357! Slip of the keyboard on someone’s part at LR perhaps or maybe fluke. 2016 SDV8 AB |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Didn't Red Merle have this issue? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
My fat fingers ![]() |
Mikey - unless you typed out the whole note I don’t think it was fat fingers - it genuinely looks like two separate references from Topix with digits switched |
My fingers saved the file to my computer as 357 |
Thanks Mikey. I had wondered if opening the covering of the original wiring would do the trick or whether the oil was migrating under the insulation. The addition of a short harness that allows oil to escape would be quick and easy to fit. I wonder what mess the escaping oil might create over time but perhaps its so little to be insignificant. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
Spotted that on Topix on mine couple of days ago. Unfortunately not much we can do about it at the moment. There is nothing that can't be fixed with a hammer😜😜
At least there's an alternative fix to removing the sump to replace the internal wiring harness. |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 ![]() ![]() ![]() |
I have had my oil level sensor fail twice with this oil issue it has cost me $7000 Australian dollars so far. Each time they told me massive job that requires sump removal and at least two days to complete.
The bulletin allows half an hour but I don't know why it would take that long!
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 234 ![]() ![]() |
Had this campaign come up for mine about a month ago. Ironically at the same time I'd been having the engine going into limp mode due to the turbo actuator dying due to oil tracking through the wiring loom. Until oil starts to seep through the turbo actuator case there is no external evidence - the waterproof connectors used keep the oil in!
