Home > Maintenance & Mods (L405) > N375 - engine oil level sensor wiring harness installation
ABAB
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
OUTSTANDING CAMPAIGNS
N375 - ENGINE OIL LEVEL SENSOR WIRING HARNESS INSTALLATION
Whilst taking a look in Topix for something else I noticed the above for my car.
Anyone know what this one is and whether urgent? 2016 SDV8 AB
Post #549845 10th Apr 2020 9:28am
Baltic Blue
https://www.fullfatrr.com/forum/topic54721.html
This link may be of interest to you...re failed oil level sensor on L405.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #549850 10th Apr 2020 9:46am
GraemeS
Australia
The original harness has a habit of migrating oil from the sump into the primary turbo's electronics, often if not always requiring a new turbo as well as the harness being replaced with the later design.
I'd like to know what the campaign notice states.
Post #549859 10th Apr 2020 12:07pm
Mikey
https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf
Apparently affects ALL SDV8's
Post #549861 10th Apr 2020 12:32pm
ABAB
Thanks for the replies - wonder if it’s coincidence that there are campaigns under N375 and N357! Slip of the keyboard on someone’s part at LR perhaps or maybe fluke. 2016 SDV8 AB
Post #549873 10th Apr 2020 3:55pm
GGDR
Didn't Red Merle have this issue?
. Cheers, Greg
Post #549875 10th Apr 2020 4:13pm
Mikey
My fat fingers Embarassed
Post #549893 10th Apr 2020 5:30pm
ABAB
Mikey - unless you typed out the whole note I don’t think it was fat fingers - it genuinely looks like two separate references from Topix with digits switched Rolling with laughter 2016 SDV8 AB
Post #549897 10th Apr 2020 5:41pm
Mikey
My fingers saved the file to my computer as 357 Thumbs Up
Unless there is another LTB00357 mentioned in the 375 bulletin
Post #549900 10th Apr 2020 6:02pm
GraemeS
Australia
Thanks Mikey. I had wondered if opening the covering of the original wiring would do the trick or whether the oil was migrating under the insulation. The addition of a short harness that allows oil to escape would be quick and easy to fit. I wonder what mess the escaping oil might create over time but perhaps its so little to be insignificant.
Post #549920 10th Apr 2020 9:57pm
Spotted that on Topix on mine couple of days ago. Unfortunately not much we can do about it at the moment. There is nothing that can't be fixed with a hammer😜😜
Post #549923 10th Apr 2020 10:36pm
GraemeS
Australia
At least there's an alternative fix to removing the sump to replace the internal wiring harness.
Post #549924 10th Apr 2020 10:59pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
I have had my oil level sensor fail twice with this oil issue it has cost me $7000 Australian dollars so far. Each time they told me massive job that requires sump removal and at least two days to complete.
The job listed by topix looks like it would take about an hour.
Me thinks they have taken me for a long ride down a very dark tunnel! Ripped Off ! ?
Post #549927 11th Apr 2020 1:52am
GraemeS
Australia
The bulletin allows half an hour but I don't know why it would take that long!
The earlier fix is similar to the 3.0 smoke problem where some vehicles had multiple turbo replacements before the updated drain was devised. My D4 had 1 turbo replacement then began blowing smoke again just after end of warranty which was cured when I fitted the revised drain.
LR can be slow to react at times. AFAIK the o-rings for the turbo oil supply pipe from the oil cooler still aren't available as LR spare parts.
Post #549929 11th Apr 2020 3:44am
Fifth Horseman
Had this campaign come up for mine about a month ago. Ironically at the same time I'd been having the engine going into limp mode due to the turbo actuator dying due to oil tracking through the wiring loom. Until oil starts to seep through the turbo actuator case there is no external evidence - the waterproof connectors used keep the oil in!
Interestingly, a service bulletin has existed for quite some time describing the symptoms of turbo actuator failure due to oil ingress and specifying this wiring 'mod' and actuator replacement. At least the actuator is now available as a separate item - not that its cheap (about half the cost of a new turbo.).
The oil tracks up by capillary action inside the cables between the conductor strands so a soldered joint should stop it. This is not the first time Landrover have been affected by this, the TD5 used in the Discovery 2 and Defender had the same problem with the injector wiring loom. It was inside the rocker cover and oil eventually tracked up to the engine ECU causing misfiring. Most TD5 owners now treat replacing this loom as part of regular maintenance.
Post #549937 11th Apr 2020 8:30am
