Home > Maintenance & Mods (L405) > N375 - engine oil level sensor wiring harness installation
Mikey
I've done 2 of these now, both logging RP faults
One had a new actuator and loom, the other just the wiring loom
Both cars were actually from the same family, and they agreed to try it that way, for my curiosity more than anything, as well as potentially saving them the £465 + VAT for another actuator
Not heard back from them, so no idea of its needing a 2nd actuator, but no news is good news, yes? Laughing
Post #549943 11th Apr 2020 9:34am
GraemeS
Australia
Fifth Horseman wrote:
The oil tracks up by capillary action inside the cables between the conductor strands so a soldered joint should stop it.
Do you know what mechanism is used to stop this migration, perhaps a section of solid wires within the plug? I though that the oil must be migrating between the wire insulation and the harness sheath as the patch loom has no sealing sheath but perhaps its been migrating both inside and outside the wire's insulation.
I'm well accustomed to the TD5 injector loom oil migration problem, having owned TD5 D2s spanning more than 10 years.
Post #549952 11th Apr 2020 10:30am
DrRob
I assume this is for L405 motors only? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #549953 11th Apr 2020 10:42am
GraemeS
Australia
Applies to the L494 SDV8 too.
Post #549967 11th Apr 2020 11:09am
Fifth Horseman
I’m unsure how L/R think the link harness will stop the oil (not actually seen one to examine) - Mikey, as you’ve fitted two do they seem “special”?
In theory oil shouldn’t be able to get into the loom in the first place.
I may modify the link lead to include soldered joints covered with adhesive lined heat-shrink tubing in each cable. I know a rigid joint on a flexible cable in a vibration prone environment may be more prone to failure but cable is cheaper than a new turbo actuator.
Post #549984 11th Apr 2020 1:49pm
Mikey
No, just 3 cables with a connector at each end
Personally, I don't see how this modification will cure it, but one has to assume that JLR engineers have done the testing, and its a success Confused
Post #549992 11th Apr 2020 2:45pm
Fifth Horseman
"success" = keeps it going until vehicle is out of warranty
Post #550004 11th Apr 2020 4:51pm
Mikey
Such a cynic Rolling Eyes Rolling with laughter
Post #550016 11th Apr 2020 6:51pm
About 50 quids worth of bits.
Might get some and do it on t’drive. There is nothing that can't be fixed with a hammer😜😜
Post #550031 11th Apr 2020 9:35pm
teldec
I take it that this is not covered by land rover if out of warranty
i dont have a FF but a sdv8 sport
thanks
Post #567076 14th Sep 2020 10:53pm
It’s a tsb so could be. Mine was dealt with as a recall rather than a warranty claim. Worth a call to your LR dealer and ask to book it in under the “recall“ number. There is nothing that can't be fixed with a hammer😜😜
Post #567077 14th Sep 2020 10:55pm
teldec
I will give it a try if not i will get the parts ready to be fitted when it is next serviced
Post #567080 14th Sep 2020 11:17pm
teldec
Booked it in for next week with my local dealer, free of charge plus a free check round as they do which will probably write the vehicle off Laughing
Post #567169 15th Sep 2020 4:46pm
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #567178 15th Sep 2020 5:07pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
More information here:
https://www.fullfatrr.com/forum/topic56693.html Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #567259 16th Sep 2020 3:38pm
