Home > Technical (L322) > EGR Leak/Replacement 4.4 TDV8
jackie-o
Netherlands
So it´s a wrap and the car is back with whole new EGR including gaskets to the cooler and block as well as a new pipe that goes from the EGR to the inlet manifold.
The mechanic believes that the EGR failed because it was covered/filled with oil leaking from the gaskets both sides of the oil cooler. The gaskets were completely gone and snapped in half as soon as he bent them. Useful to keep in mind for those of you who have not had them changed!
Also replaced the famous o-rings and the upgraded 4 short inlet hoses.
New coolant and an oil change, which he insisted on, and hopefully I will be able to drive it for a few days before anything else breaks Banging Head
Mechanic estimates he spent around 20 hours all in all but was still kind enough to only charge me for the 11 hours he originally quoted me.
Thanks for all the input along the way, this forum is truly an asset! RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #553905 14th May 2020 6:29pm
DrRob
Good news! Yes, new oil and coolant is a must after that job Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #553907 14th May 2020 7:11pm
Range Rover L322
Land Rover has a standard charge for getting to the EGR.
I'd need to check my receipts but I think it's 9 hours labour and they charge about £1100.
Post #554266 17th May 2020 11:59pm
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Ive just had mine into landrover Unfortunately and they have Quoted me £1800 for the EGR and again he has said that's a 10Hour job Cam Tech was to busy Big Cry
Post #597863 17th Jun 2021 8:46pm
DrRob
Take it one of the other specialists around you e.g. Oval Autos, Alltrack, Coseley 4x4, James French.
Lavender Hall Autos (?)
Avoid a main dealers Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #597881 18th Jun 2021 7:07am
Simran0211
I’m in Coventry but will call lavender hall motors or bite the bullet and do it myself if there to busy 👍👍
Post #598112 20th Jun 2021 5:22am
Simran0211
Updated I have replaced the complete EGR unit proper bitch of a job but it did take me longer than the 11hours quoted by LR but they would have that manual and other items to hand. The total cost was almost £600 but that did include two oil changes, But after changing that I now have the following codes
P0409-16(27)
P0486-17(27)
P0403-13(27)
Any help would be greatfull and where the sensors would be to replace. Thumbs Up
Post #600567 13th Jul 2021 9:43pm
Landyandy1765
United Kingdom 2010 Range Rover Vogue SE TDV8 Baltic Blue
Can you confirm you was leaking oil or Coolant .
many thanks
andy
Post #626111 13th Mar 2022 10:08pm
Landyandy1765
jackie-o wrote:
@Craig; thats pretty much what he said too...
The theory is now that the leak is coming from a steel pipe going from the EGR (couldn't understand exactly which one)
He has tried looking with a a camera but it´s too tight to see anything and the whole thing now needs to come out which apparently is a real PITA Sad
The saga continuous...
Was it a coolant leak or oil?
Regards
Post #626112 13th Mar 2022 10:25pm
Simran0211
It was oil leaking at the back of the oil cooler and on the main gasket so I had done both and had changed the oil and water, because when you take of the oil the water mixes with the oil. Lesson learned drain oil and water first to stop crossing them over.
Post #626229 15th Mar 2022 2:42pm
Landyandy1765
thanks for the update
Post #626246 15th Mar 2022 7:19pm
