Home > Technical (L322) > EGR Leak/Replacement 4.4 TDV8 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Good news! Yes, new oil and coolant is a must after that job Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th May 2020 7:11pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Land Rover has a standard charge for getting to the EGR.
17th May 2020 11:59pm |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 299 |
Ive just had mine into landrover Unfortunately and they have Quoted me £1800 for the EGR and again he has said that's a 10Hour job Cam Tech was to busy |
17th Jun 2021 8:46pm |
Take it one of the other specialists around you e.g. Oval Autos, Alltrack, Coseley 4x4, James French.
18th Jun 2021 7:07am |
I’m in Coventry but will call lavender hall motors or bite the bullet and do it myself if there to busy 👍👍 |
20th Jun 2021 5:22am |
Updated I have replaced the complete EGR unit proper bitch of a job but it did take me longer than the 11hours quoted by LR but they would have that manual and other items to hand. The total cost was almost £600 but that did include two oil changes, But after changing that I now have the following codes
13th Jul 2021 9:43pm |
Landyandy1765 Member Since: 25 Mar 2019 Location: bournemouth Posts: 56 |
Can you confirm you was leaking oil or Coolant . many thanks andy |
13th Mar 2022 10:08pm |
Was it a coolant leak or oil? Regards |
13th Mar 2022 10:25pm |
It was oil leaking at the back of the oil cooler and on the main gasket so I had done both and had changed the oil and water, because when you take of the oil the water mixes with the oil. Lesson learned drain oil and water first to stop crossing them over. |
15th Mar 2022 2:42pm |
thanks for the update |
15th Mar 2022 7:19pm |
