Home > Technical (L322) > P023d - 22 (6c) |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 |
Having now done a search and read all I can find, I have checked as best I can without dismantlling the plastic inlet manifold which seems clean and no evidence of soot, just a little oil at the back.
22nd Feb 2020 12:50pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1760 |
Remove the lower intercooler hoses, and check for excessive oil... |
22nd Feb 2020 1:41pm |
OK, will do, and if there is..... |
22nd Feb 2020 1:52pm |
22nd Feb 2020 10:05pm |
Hey Mikey, I hope you are around today.
23rd Feb 2020 11:43am |
I guess my real problem is finding someone with the knowledge and experience close enough to me in Valencia. The only option may be the local Main Dealer |
23rd Feb 2020 11:45am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35324 |
i used the forum search function and came up with these threads,
23rd Feb 2020 11:57am |
Small amounts of oil is perfectly acceptable. Sounds as though you have a boost leak, be it a top intercooler hose or cracked manifold A smoke test would highlight any issues |
23rd Feb 2020 1:16pm |
Thanks Stan and Mikey, Stan I had found and read some of those threads, but there where a couple I had not. Thanks Mikey, I was beginning to doubt turbo after the no oil in hoses. So, more investigation needed. Can you briefly describe how a smoke test is performed please. |
23rd Feb 2020 1:21pm |
https://m.facebook.com/story.php?story_fbi...9706667330
23rd Feb 2020 3:42pm |
Thanks Mikey, clearly not something I can do myself, need to find a specialist now. |
23rd Feb 2020 4:05pm |
