![]() | Home > Technical (L322) > TD6 sounds like a plane when turned off |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Viscous fan coupling, could be duff so builds the fan up slowly when running and hasn’t got the friction to slow it down on shut down. There is nothing that can't be fixed with a hammer😜😜
or the FBH (Fuel Burning Heater) .
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 761 ![]() ![]() ![]() |
Cheers guys
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 ![]() ![]() ![]() |
FBH - mine does the same 2004 Vogue TD6 - Remapped |
The other chaps could be on the right track with the FBH. It does sound a bit jet engine when running.
It is actually around the passenger side wheel arch, yes... Only for about 15 seconds maybe after turning the RR off
