Home > Technical (L322) > TD6 sounds like a plane when turned off
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Our Td6 when you turn it off after a drive sounds like a jumbo jet engine shutting down (albeit nowhere near as loud), only for a few seconds. Never noticed it before (or paid much attention to it maybe)
Just wondering what it is, and if its normal? Noise comes from the front by the way
Post #544752 22nd Feb 2020 8:53am
Viscous fan coupling, could be duff so builds the fan up slowly when running and hasn’t got the friction to slow it down on shut down. There is nothing that can't be fixed with a hammer😜😜
Post #544753 22nd Feb 2020 8:55am
or the FBH (Fuel Burning Heater) .
Post #544764 22nd Feb 2020 10:37am
mrblonde
Cheers guys
Joe90 - not sure mine has the FBH, or at least I haven’t got the remote for it or ever seen or used it
Northernmonkey - is it a hard job to replace? And can it be left for a while as I have a few more pressing jobs to do first Sad
Post #544835 22nd Feb 2020 9:22pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
FBH - mine does the same 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #545034 24th Feb 2020 4:40pm
The other chaps could be on the right track with the FBH. It does sound a bit jet engine when running.
See if the noise is loudest in the passenger side wheel arch area. That is where the FBh is located. There is nothing that can't be fixed with a hammer😜😜
Post #545053 24th Feb 2020 6:47pm
mrblonde
It is actually around the passenger side wheel arch, yes... Only for about 15 seconds maybe after turning the RR off
I had no idea it has an FBH, and have never used it Embarassed
Post #545288 27th Feb 2020 2:51am
