Home > Technical (L322) > Restricted Performance Red Light |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3523 |
The ECU records every momentary error.
29th Jan 2020 10:33am |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
Thanks Greg,
29th Jan 2020 11:09am |
Btw, any idea what the "whisteling/whining" noise could be? RR Vogue 4.4 TDV8 - 11
29th Jan 2020 11:58am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4286 |
Get it to a LR expert and diagnose the leak. Could be a failing turbo Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
29th Jan 2020 12:06pm |
Booked at LR main dealer tomorrow morning, hope to god I dont need to change any turbos RR Vogue 4.4 TDV8 - 11
29th Jan 2020 3:24pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Could it not be the 4 short hoses on the intake? BMW i3 Electric Car
29th Jan 2020 3:32pm |
AJ, Sounds preferable to a new turbo...
29th Jan 2020 3:37pm |
Have a look here https://www.fullfatrr.com/forum/topic26796-30.html
29th Jan 2020 4:30pm |
Oil leak could be the oil cooler gasket or the 2 o rings on the pipe into it. Lots on here. Easy to diagnose.
29th Jan 2020 6:33pm |
@ Rob, last garage diagnosed it as the oil cooler gaskets but only that the car was "sweating" oil so thought I´d have it fixed and next oportunity, let´s see if the main dealer comes to the same conclusion...
30th Jan 2020 9:36am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
If you get a chance, take the engine cover off and shine a torch into the middle of the V of the engine.
30th Jan 2020 10:22am |
Thanks mrpirie.
30th Jan 2020 10:29am |
How many miles on your RR jackie?
30th Jan 2020 10:34am |
Greg, it´s almost exactly at 80k miles but belts and pully´s were already done 2 years ago : )
30th Jan 2020 11:39am |
