Home > Technical (L405) > L405 Climate/Ac Heater issue. 2014 Model
L322 and L405s
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
heater does not heat the cabin
We have done all of the things mentioned below, but to no avail, the heater appears to be working, but no heat is getting in to the cabin, surely someone else has had this problem and managed to fix it ?? Rolling Eyes
Post #678001 15th Nov 2023 4:24pm
rattly
I’m having same problem, did anyone ever get to the bottom of it please?
Post #699893 10th Sep 2024 5:18pm
supershuttle
Mine does exactly the same, just stops being warm after a while unless you turn the temp up a few degrees Geoff
Post #699899 10th Sep 2024 7:07pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
If you have the auxiliary fuel fired burner heater (FFBH) (standard on the SDV8) it's more than likely the coolant diverter valve on the bottom of the unit. Easy change and not too expensive. Easy check is feel the temperature of the 2 hoses going up to the EGR, if they are dissimilar, then that's definitely your problem. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #699907 10th Sep 2024 8:44pm
