Home > Technical (L405) > L405 Climate/Ac Heater issue. 2014 Model |
rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 42 |
I’m having same problem, did anyone ever get to the bottom of it please? |
10th Sep 2024 5:18pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3852 |
Mine does exactly the same, just stops being warm after a while unless you turn the temp up a few degrees Geoff |
10th Sep 2024 7:07pm |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 250 |
If you have the auxiliary fuel fired burner heater (FFBH) (standard on the SDV8) it's more than likely the coolant diverter valve on the bottom of the unit. Easy change and not too expensive. Easy check is feel the temperature of the 2 hoses going up to the EGR, if they are dissimilar, then that's definitely your problem. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
10th Sep 2024 8:44pm |
