Home > Maintenance & Mods (L322) > Anderson connector from front to battery
Jim_m_kidd
2015 Range Rover Autobiography SDV8 Loire Blue
Thanks! Mission accomplished this morning. The housing does eventually come free, just needs a good hard pull.
Post #542634 1st Feb 2020 1:10pm
Post #542642 1st Feb 2020 2:03pm
pcourtney
when I go on holiday for a few weeks, and leave my car at the airport, I do worry about coming back to a flat battery Sad
not that I have tested it yet, but I do have a very small Petrol generator in the boot, Makro used to sell them cheap years ago, it has a single 13amp socket that allows me to plug my CTEK MXS 5.0 into it, I also have a 10m cable extension reel so the petrol fumes don't enter the car
the clever bit is the APS in the rear boot of the car (page 112 owners handbook), RR call it an Auxiliary Power Socket (APS) , but it's just another cigar lighter socket, and it's always active (it does not need the ignition to be in the on position for it to work) !
so I bought a CTEK accessory cable off ebay for £10 quid that connects the CTEK Comfort Connector to the cigar lighter socket, so I could fire up the genny, and maybe ten mins later turn the key and hopefully the engine starts, maybe leave it for another 5 mins for all the other electrical stuff, ECU's and heating to work, then disconnect the CTEK and turn off genny.
NB am only doing it this way, because I already have a CTEK charger and petrol genny (which I use for work about once a month)
The cable is pretty thin on the CTEK ( it is Swedish made ) , but they must know what they are doing, but the cable they use is thinner than my battery booster cables, but then the cable from the APS to the battery is also on the thin side, as shown below
so I just just assuming it has a chance of working Idea
Post #542664 1st Feb 2020 5:13pm
Leesbay
England 2011 Range Rover SE TDV8 Zambezi Silver
All sorted
I have taken heavy duty jump lead cable from battery to anderson connector on front to assist with jumping a dead battery and also for plugging in my intelli charger which has anderson fittings👍
Post #542863 3rd Feb 2020 12:32pm
Gremlin500
Post #626495 19th Mar 2022 5:57pm
GraemeJudge
2004 Range Rover Vogue Td6 Java Black
Leesbay wrote:
Ideally want an external point so i can plug in and charge without opening bonnet especially if car is locked and to save faffing around with manual key opening
Looked in side vent but doesnt appear to be any easy access through to engine bay so prob mount under front bumper with waterproof cap for easy access and jump starting
Is this the sort of think. This is where I mounted mine just below the parking sensor with cover and comes in very handy to both jump start others or when the battery gets low to be able to get access I also have two 3 meter leads so no restrictions on how close the cars have to be together
Post #626620 21st Mar 2022 2:44pm
Gremlin500
Post #626622 21st Mar 2022 3:03pm
