Home > Technical (L405) > Has you crankshaft failed? L405 3. 0 TDv6 only!
Has your L405 3.0 Crankshaft failed?
My L405 3.0 Crankshaft failed (fixed by LR Wrrnty/ other wrrnty)
2%
 2%  [1]
My L405 3.0 Crankshaft failed (fixed via goodwill)
0%
 0%  [0]
My L405 3.0 Crankshaft failed (left high & dry by LR/ wrrnty co.)
9%
 9%  [4]
No issues with my L405 3.0 Crankshaft (to date)
88%
 88%  [38]
Total Votes: 43
Gremlin500
I’m just basking in my new title Lord of Pedantry, any complaints please address to the Houses of Parliament, my usual PO Box. Twisted Evil Rolling with laughter
But, slightly more seriously, naysers of a different ilk risk polluting the genuine L405 data being accumulated in this thread, no?
My 2021 Ford Ranger is p*ssing oil out of its off-topic engine and its crankshaft may yet fail, but would I mention it on here?
Sorry, Off Topic “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #658289 2nd Mar 2023 9:34pm
ash83
United States
I would encourage anyone who has had a failure on these engines in the US to submit a complaint:
https://www.nhtsa.gov/report-a-safety-problem
I had a 2011 Cayenne S that had an almost catastrophic engine issue and did the complaint, as did many owners, and it became a recall.
It is a safety issue after all. Anything that disables a vehicle at highway speeds is a safety issue.
Post #696684 22nd Jul 2024 10:55pm
Gremlin500
Wow!
16 months have gone by, and not a single instance reported to this thread, that says something.
Post #696686 22nd Jul 2024 11:03pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Based on this thread it would seem that TDV6 crank failures are not as common as you would believe based on the noise on the internet about them. I would have expected to see far more reports of failure on this thread, but great to see that is not the case.
Post #696722 23rd Jul 2024 12:18pm
Mikey
Start a new poll with the Ingenium lumps Whistle Laughing
Post #696751 23rd Jul 2024 7:09pm
is that the 2litre ones mainly fitted to the D5? ... - .- -.
Post #696762 23rd Jul 2024 9:22pm
Gremlin500
Yes and the Evoque/Dsport.
Post #696763 23rd Jul 2024 9:27pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I thought the ingenium 2.0 was a lot more reliable?
Post #696767 23rd Jul 2024 10:49pm
Gremlin500
@DrF:
At my last service in April, my local indy LR specialist could hardly move vehicles around their 6-bay workshop for new crated Ingenium engines waiting to go into busted vehicles, so they said.
Not sure if it’s crankshafts or other terminal issues? Our own 2016 Evoque HSE 2.2D was totally faultless over 3 years, not one single issue.
Again, being my usual pedantic self, we are in danger of going OT on this thread, where it seems the tumbleweed speaks volumes against the desktop mechanics preaching TDV6 crankshaft woes.
I feel cheated as an adrenaline junkie, having only purchased a TDV6 for the expected sudden thrill of a snapped crankshaft, only to find myself a victim of Internet bullsh*t. :censored:
Post #696773 24th Jul 2024 1:25am
Mikey
3.0 straught 6 lumps too, in the newer models...
Post #696836 24th Jul 2024 8:56pm
thanks Mikey Thumbs Up ... - .- -.
Post #696853 25th Jul 2024 7:56am
caymanblack
Is that the D350 engines also Mikey? overfinch modified
Post #696872 25th Jul 2024 2:51pm
Philip
The six cylinder Ingeniums don’t seem to be anything like as bad as the older four cylinder ones. Nice engine too.
Post #696927 26th Jul 2024 9:44am
Mikey
Post #697154 30th Jul 2024 5:38pm
garyRR
My reading of your results is that rule of thumb is 2:1 of aluminium to silicone and you're below this limit, so is not of concern yet.
Cranks are forged steel though. The aluminium, to me, signifies cylinder head wear ‐ either piston or cylinder walls, which wouldn't be unexpected on a 10 year old vehicle. I think this may also explain your elevated level of oil dilution, but still low soot level.
Does the oil test not provide an analysis report? I have seen some before which give an expert opinion based on the result.
If the car runs fine and you don't get issues with blow-by etc, I'd keep up with the oil changes and test again in 5,000 miles. 2015 Range Rover Autobiography 4.4 SDV8
Post #697171 31st Jul 2024 1:49am
