![]() | Home > Technical (L405) > Has you crankshaft failed? L405 3. 0 TDv6 only! |
ash83 Member Since: 21 Jul 2024 Location: NYC Posts: 34 ![]() ![]() |
I would encourage anyone who has had a failure on these engines in the US to submit a complaint:
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1689 ![]() ![]() ![]() |
Wow!
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 169 ![]() ![]() ![]() |
Based on this thread it would seem that TDV6 crank failures are not as common as you would believe based on the noise on the internet about them. I would have expected to see far more reports of failure on this thread, but great to see that is not the case. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
Start a new poll with the Ingenium lumps |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
is that the 2litre ones mainly fitted to the D5? ... - .- -.
Yes and the Evoque/Dsport. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1467 ![]() ![]() ![]() |
I thought the ingenium 2.0 was a lot more reliable? |
@DrF:
3.0 straught 6 lumps too, in the newer models... |
thanks Mikey |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
Is that the D350 engines also Mikey? overfinch modified |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
The six cylinder Ingeniums don’t seem to be anything like as bad as the older four cylinder ones. Nice engine too. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1484 ![]() ![]() |
My reading of your results is that rule of thumb is 2:1 of aluminium to silicone and you're below this limit, so is not of concern yet.
