Home > Maintenance & Mods (L322) > Retrofitting PDC |
PovertySpec Member Since: 28 Nov 2019 Location: Durham Posts: 35 |
Hi All,
19th Dec 2019 1:06pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
You might find its much cheaper / easier to fit an aftermarket kit.
23rd Dec 2019 10:48am |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 84 |
Mine has a sounder in the rear of the car, under the drivers side parcel shelf side trim, the panel that sits below the rear side glass. It’s an approximate 2” deep by 2” diameter, black speaker unit. I assume there will be a similar unit at the front and both have different pitch to differentiate between front and rear. Hope that makes sense and is of help. 2012 Westminster TDV8 4.4 Indus Silver
23rd Dec 2019 9:27pm |
Thanks for all the comments - I appreciate everyone's input.
24th Dec 2019 9:03am |
Just a little update to this....it would appear it is indeed possible and I have made a little progress.
2nd Mar 2020 3:50pm |
Further update - front bumper fitted with parking sensors, and now that the ECU is playing, I was able to check everything. There are two failed sensors on the front, but the rears still don't want to play - testing via diagnostic tool shows they are working correctly so I'm assuming at this point, the car needs to be told PDC is fitted and activated.
7th Mar 2020 7:00pm |
Final update - all working!!
15th Mar 2020 9:07pm |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
Well done. If you keep adding extras you'll have to change your username! |
15th Mar 2020 10:48pm |
