Home > Maintenance & Mods (L322) > Retrofitting PDC
PovertySpec
England 2003 Range Rover SE Td6 Zambezi Silver
Retrofitting PDC
Hi All,
Before my current foray into the L322, I used to have a Rover 75, then MG ZT, then MG ZT-T.....and one of the things I used to enjoy was retrofitting various dealer extras, a lot of it being the same BMW sat nav from the early vehicles. Now, I have no plans to do that particular task on the L322, but what I have been looking at is Parking Sensors, or Parking Distance Control as I think it is referred to here?
So....first question, has anyone attempted this previously, and if so, any glaring things that I need to be aware of?
I'm looking to replace the rear bumper anyway at some point, so I was going to get one with parking sensors in, get the ecu, and fit them. I also believe I'll need to fit the switch on the console where the air suspension controls are / replace that panel, but what I can't tell is if a stand alone parking sounder is needed or if the sound is generated by the instrument cluster or similar.
I'm willing to bet it'll need to be coded onto the L322 as well, but I'm just trying to see if it's possible first.
Post #537899 19th Dec 2019 2:06pm
Danwilderspin
I thought they all had pdc!!
You will need the pdc module <£20 eBay , 4 sensors or 8 if doing front to (I seem to think you have to do front and back) both bumpers.
I may be wrong but pretty sure it doesn’t even need coding as the module just sits on the ibus Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #538271 23rd Dec 2019 12:28am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
You might find its much cheaper / easier to fit an aftermarket kit.
I fitted a set to our Discovery 2 rear bumper for all of £15 via eBay seller "Londoncolour".
They work as well as the "OE" versions on our 2007 L322.
The only minor difficulty you might have is colour coding them - but probably the same problem for second hand OE sensors.
You can buy aftermarket kits for front + rear too. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #538286 23rd Dec 2019 11:48am
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Mine has a sounder in the rear of the car, under the drivers side parcel shelf side trim, the panel that sits below the rear side glass. It’s an approximate 2” deep by 2” diameter, black speaker unit. I assume there will be a similar unit at the front and both have different pitch to differentiate between front and rear. Hope that makes sense and is of help. 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #538352 23rd Dec 2019 10:27pm
PovertySpec
Thanks for all the comments - I appreciate everyone's input.
If I wasn't going to replace the rear bumper at some point, aftermarket would probably make more sense, but I figure I can get everything I need cheap enough and have it OEM. I did something very similar with an MG ZT, and given it's probably the same tech, then it should be a very comparable exercise.
The sounder sounds (forgive the pun) pretty much identical to what I expected, I think a quick check to see if the connector is tucked away is in order, but so far it sounds promising.
Post #538377 24th Dec 2019 10:03am
PovertySpec
Just a little update to this....it would appear it is indeed possible and I have made a little progress.
As I previously mentioned, I wanted to replace the rear bumper anyway, and found one with parking sensors and loom included. I sourced an ECU and rear speaker, plus the centre console section with the additional PDC button.
The wiring connectors for the loom and speaker were tucked away, so just plugged everything in and it appears to be working, in as much as there is a fault beep. I'm going to connect the front up, and if necessary, give my friend with a T4 a visit just to make sure it's fully enabled, and see whats generating the long beep.
I'll update again once I get it all finished.
Post #545801 2nd Mar 2020 4:50pm
PovertySpec
Further update - front bumper fitted with parking sensors, and now that the ECU is playing, I was able to check everything. There are two failed sensors on the front, but the rears still don't want to play - testing via diagnostic tool shows they are working correctly so I'm assuming at this point, the car needs to be told PDC is fitted and activated.
Still, progress is progress. Laughing
Post #546343 7th Mar 2020 8:00pm
PovertySpec
Final update - all working!!
Front Sensors were fine, just a couple of loose connectors and once firmly pushed home, everything kicked in with no further programming needed.
Nice positive end, so naturally to counterbalance that I now have a grumbling bearing. Cosmic balance in action I suppose.
Post #547261 15th Mar 2020 10:07pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Well done. If you keep adding extras you'll have to change your username!
Post #547274 15th Mar 2020 11:48pm
