Home > General (L405) > New FFRR Owner Checking In |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Welcome aboard sir...
3rd Dec 2019 12:53pm |
GB78 Member Since: 03 Dec 2019 Location: Essex Posts: 70 |
Ah ha
3rd Dec 2019 1:04pm |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 |
I would think that information and more is on your screen using the steering wheel controls or indicated stalk button 👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
3rd Dec 2019 1:30pm |
No, tried that first. My F10 has all sorts of service info, but i can't find squat on this. |
3rd Dec 2019 1:49pm |
peanutbob Member Since: 02 Mar 2013 Location: UK Posts: 57 |
I think the distance to service on the menu only appears when ignition on and engine stopped...it does on mine but it’s a later year . But you will also receive a message on screen when about 1k to go. |
3rd Dec 2019 6:50pm |
Ok thanks, I will have a try. I most likely had the engine running when i last looked. I am curious on the countdown as I have been reading some interesting posts on the later versions having very short or "early" oil changes. |
4th Dec 2019 8:03am |
If you cover less miles per year then it will be a yearly countdown... If you do higher miles then it depends how you drive as to how many miles you get between services... I.E. lots of short journeys compared to long motorway jaunts |
4th Dec 2019 10:48am |
SHMBO does approx 5-6000 miles a year. So I knew it would be the anniversary of the service that got me over the mileage.
4th Dec 2019 11:23am |
ilard Member Since: 21 Oct 2012 Location: London Posts: 708 |
you can also check the spec of the car using Land Rover topix or https://www.vindecoderz.com/EN/check-lookup/ (put your VIN after ‘lookup/)
4th Dec 2019 8:38pm |
