Home > General (L405) > New FFRR Owner Checking In
GB78
England 2014 Range Rover Vogue SE TDV6 Santorini Black
Hi All
Had my MY14 VSE for a couple of months now and must say i'm in LOVE so far. Its a real pleasure to drive, compared to my previous Merc W166.
Quick newbie question however, on the spec list is states 4 zone climate, but it seems when 1 rear passenger changes the temp it adjusts the other side as well?
Any info appreciated, I have been so busy since acquiring it I haven't had much opportunity to investigate myself.
Thanks in advance
Post #536248 3rd Dec 2019 12:03pm
Welcome aboard sir...
Check the rear seat L&R controls have not been "Sync'd" that way L&R mimic each other... Thumbs Up
Post #536250 3rd Dec 2019 12:53pm
GB78
Ah ha
I will have a good look later at that, Thanks Thumbs Up
Also i just got it serviced at my local dealer, and wondered if I would get a countdown to the next service. I couldn't find anything scouring over the menus. Will it tell me or is it designed to be a nice surprise one morning?
Post #536253 3rd Dec 2019 1:04pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
I would think that information and more is on your screen using the steering wheel controls or indicated stalk button 👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #536262 3rd Dec 2019 1:30pm
GB78
No, tried that first. My F10 has all sorts of service info, but i can't find squat on this.
Post #536269 3rd Dec 2019 1:49pm
peanutbob
United Kingdom 2018 Range Rover Vogue SE SDV8 Santorini Black
I think the distance to service on the menu only appears when ignition on and engine stopped...it does on mine but it’s a later year . But you will also receive a message on screen when about 1k to go.
Post #536303 3rd Dec 2019 6:50pm
GB78
Ok thanks, I will have a try. I most likely had the engine running when i last looked. I am curious on the countdown as I have been reading some interesting posts on the later versions having very short or "early" oil changes.
Post #536335 4th Dec 2019 8:03am
If you cover less miles per year then it will be a yearly countdown... If you do higher miles then it depends how you drive as to how many miles you get between services... I.E. lots of short journeys compared to long motorway jaunts Thumbs Up
Post #536346 4th Dec 2019 10:48am
GB78
SHMBO does approx 5-6000 miles a year. So I knew it would be the anniversary of the service that got me over the mileage.
Thanks Thumbs Up
Post #536347 4th Dec 2019 11:23am
ilard
you can also check the spec of the car using Land Rover topix or https://www.vindecoderz.com/EN/check-lookup/ (put your VIN after ‘lookup/)
Sometimes suppliers get muddled of the intricacies of the spec, whereas this source should be authoritative. You don’t have to be a professor of JLR to understand these spec sheets, but it helps Laughing L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #536387 4th Dec 2019 8:38pm
