![]() | Home > Maintenance & Mods (L405) > Xenon Upgrades? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
...also if you have a tdv6 theres only the nearside you need to strip down...the rear of the offside light is easily accessible.. ... - .- -.
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 ![]() ![]() |
Hi Phil,
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
Many thanks for the additional info. I'll have to take another go when it warms up a bit. MY23 D350 HSE
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Has anyone tried running a 50w ballast with their L405 HIDs/housings? You can get them from retrofitsource and I’ve used them in the past and they do make quite a bit more light. 2014 FF Autobiography 5.0 SC
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 ![]() ![]() ![]() |
Can you be more specific? I have no idea what a 50W Ballast is - and if I go to the retrofit source website, they don't list Land Rover or Range Rover in their offerings. 2017 4.4 SDV8 Autobiography |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2660 ![]() ![]() |
What wattage are the original bulbs? If 50W like the late L322s then the ballasts will also be 50W which will run 35W globes but the globes wont last as long as they should. |
Aftermarket. Not OEM. Select 50w from the drop down. https://www.theretrofitsource.com/morimoto...lasts.html The OEM ballasts put out 35w (all OEM does). But these will put out 50w to the HID capsule. The result is much brighter light and possible slight bulb life. But it’s a fair trade off. The 50w will also lower the temp so if you have a 5000k bulb you can expect slightly lower to that of 4300k.....but you get more lumens. When I was into retrofitting I did this on other cars. I also ran 50w HID bulbs (Which look like regular capsules on steroids....they are fatter). But you can run the regular capsules with the 50w ballasts as well. Was curious if anyone did this on the OEM housings to see how much more output you get. 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
i'm pretty sure 50w bulbs are illegal in the UK...the standard is 35w... ... - .- -.
No one needs to know |
Old skool rules Member Since: 03 Feb 2019 Location: Staffordshire Posts: 29 ![]() ![]() |
I've done mine, simple enough job as has been explained earlier in the thread.
I’ve just put in Osram cool blue advanced. I believe rates at 6000k @ 3200 lumens. These are 100% white with NO hint of yellow. Basically match the DRL perfectly if that’s what’s you want. It is what I wanted so I’m happy with the color. They haven’t broken in yet so hard to say about brightness but new I’d say about same as stock...just totally white.
LT Member Since: 13 Mar 2017 Location: South West Posts: 414 ![]() ![]() ![]() |
Thread Revival:
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
I have a pair of Osram Night Breaker DS3s which I removed from my L405 before I sold it.
Thanks for the offer, but at this stage I'm seeking advice as to which replacement bulbs are now considered to be the best. |
