Home > Maintenance & Mods (L405) > Xenon Upgrades?
Page 3 of 5 <12345>
...also if you have a tdv6 theres only the nearside you need to strip down...the rear of the offside light is easily accessible.. ... - .- -.
Post #540048 10th Jan 2020 2:43pm
Phil.
MacPaul - Did you need to take the air boxes apart or did you manage to move them enough as they are? I ask because I began the job taking LHS (near-side) air box apart and gave up after an hour because it seemed too difficult for me. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #540050 10th Jan 2020 3:05pm
Macpaul
2019 Range Rover Vogue SE 2.0 PHEV Siberian Silver
Hi Phil,
I separated the top of the airbox from the bottom.
(There are only six captive screws holding the two halves together).
On the RHS I undid the jubilee clips and took off the ducting as per my pics. Not necessary on the nearside.
You can then drape the top of the airbox toward the middle of the engine.
That then allows you simply to lift out the bottom half of the airbox which is simply a push-fit into three rubber-grommeted holes.
Once you've got the bottom of the airbox out of the way, you can take the little rubber cap off where the bulb lives.
If you weren't so far I'd do it for you - I'd be much quicker next time.
Post #540054 10th Jan 2020 3:48pm
Phil.
Many thanks for the additional info. I'll have to take another go when it warms up a bit. MY23 D350 HSE
Post #540061 10th Jan 2020 4:56pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Has anyone tried running a 50w ballast with their L405 HIDs/housings? You can get them from retrofitsource and I’ve used them in the past and they do make quite a bit more light. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #540837 17th Jan 2020 6:17am
awclymm
Can you be more specific? I have no idea what a 50W Ballast is - and if I go to the retrofit source website, they don't list Land Rover or Range Rover in their offerings. 2017 4.4 SDV8 Autobiography
Post #540840 17th Jan 2020 8:29am
GraemeS
Australia
What wattage are the original bulbs? If 50W like the late L322s then the ballasts will also be 50W which will run 35W globes but the globes wont last as long as they should.
Post #540853 17th Jan 2020 9:51am
horse86
Aftermarket. Not OEM. Select 50w from the drop down.
https://www.theretrofitsource.com/morimoto...lasts.html
The OEM ballasts put out 35w (all OEM does). But these will put out 50w to the HID capsule. The result is much brighter light and possible slight bulb life. But it’s a fair trade off. The 50w will also lower the temp so if you have a 5000k bulb you can expect slightly lower to that of 4300k.....but you get more lumens.
When I was into retrofitting I did this on other cars. I also ran 50w HID bulbs (Which look like regular capsules on steroids....they are fatter). But you can run the regular capsules with the 50w ballasts as well.
Was curious if anyone did this on the OEM housings to see how much more output you get. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #540883 17th Jan 2020 3:35pm
i'm pretty sure 50w bulbs are illegal in the UK...the standard is 35w... ... - .- -.
Post #540884 17th Jan 2020 3:45pm
horse86
No one needs to know Wink Wink
But that’s fine...just use the 50w ballasts with the stock HID capsules. Kind of a cheat code to get more lighting for you guys too. No one is going to test the wattage your unmarked ballast is putting out 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #540886 17th Jan 2020 3:58pm
Old skool rules
I've done mine, simple enough job as has been explained earlier in the thread.
I bought the Philips X-tremevision Gen 2, only to find Osrams in the holders already, but no matter. I still did the change over and not much difference if I'm honest. Best thing I did was raise the headlight beam up a small amount to give better coverage.
The problem really is the lenses, they are just so poor at projecting the light forwards any great distance and with any sort of real depth.
My previous Audi A5 could have taught Land Rover a thing or two about headlights ... and reversing lights Laughing
cheers
Rob .
It's better to ask for forgiveness than ask for permission ......... apparently!
2017 4.4 SDV8 Range Rover Autobiography
Ligurian Black Exterior / Ivory Interior
2016 3.0 SDV6 Range Rover Sport HSE Dynamic
Firenze Red / Black Pack / Black interior
Subaru Impreza WRX STI Spec C Type RA 2005
Mitsubishi Lancer EVO VI Tommi Makinen Edition
Post #543692 11th Feb 2020 10:47pm
horse86
I’ve just put in Osram cool blue advanced. I believe rates at 6000k @ 3200 lumens. These are 100% white with NO hint of yellow. Basically match the DRL perfectly if that’s what’s you want. It is what I wanted so I’m happy with the color. They haven’t broken in yet so hard to say about brightness but new I’d say about same as stock...just totally white.
But yea like above said. The lenses are these projectors are just junk for letting light out. If we had 100% clear lenses in them it would be much brighter output and sharper cutoff
I had Honda S2000 projectors in one retrofit I did long ago so I will always be biased. That’s was the GOAT projector for cutoff width and intensity 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #543699 12th Feb 2020 2:46am
LT
Thread Revival:
My eyes are getting older and the lights on my MY17 L405 are definitely getting dimmer.
Are the Osram's still the go to bulb replacement, or is there anything better on the market?
Post #654620 24th Jan 2023 7:28pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I have a pair of Osram Night Breaker DS3s which I removed from my L405 before I sold it.
I can let you have them for £50 plus postage. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #654658 25th Jan 2023 9:44am
LT
Thanks for the offer, but at this stage I'm seeking advice as to which replacement bulbs are now considered to be the best. Thumbs Up
Post #654701 25th Jan 2023 7:04pm
Page 3 of 5 <12345>
