Home > Technical (L322) > Rover All Comms - First Look
Page 5 of 7 <1234567>
sportin
United States 2006 Range Rover HSE 4.4 V8 Java Black
I have MY2006....I'm interested to see if this will work on it. I know the vin stops 5A999999, but the 06MY still some BMW systems... Just my luck, I will need to this one and the new top secret model to cover all of the systems in the 06MY Sad waaaaayyyyy 2006 RR 4.4 HSE
2008 Audi A6
Post #61425 25th Apr 2011 1:27am
available today according to the website.. ... - .- -.
Post #61455 25th Apr 2011 12:08pm
Olders
My 07MY (late 06 production) FFRR has the triple flash indicators. Perhaps suggesting it was the 06/07 onwards cars with the updated interiors that had the triple flash 'lazy' indicators?
Good function though - only wish it was 4 flashes not 3! -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #61565 26th Apr 2011 10:12am
snugg
United States 2008 Range Rover HSE 4.4 V8 Stornoway Grey
Scarey,
I also have a 2005 model and just ordered the RAC today. Could you post some of the problems that are having?
thanks
Post #61645 26th Apr 2011 9:44pm
hi snugg, if you mean 'problems i am having' then the answer is none at the moment..i got it just in case i need to clear a fault in the future and for the extras it can do .. ... - .- -.
Post #61673 27th Apr 2011 8:20am
snugg
Ok, thanks alot scarey!
Post #61710 27th Apr 2011 5:02pm
snugg
Has anyone with a 2005 (touch screen) been able to get the RAC body module function to work? I am able to read and clear faults, but when I enter the body control function, it does not read what the current settings of the truck are. Also I tried to turn on the emergency siren and nothing happened.
Thanks in advance!
Post #62352 1st May 2011 11:11pm
snugg, mine is the same as yours and i have the same problem..apparently the bcm [which is under the passenger seat] is different to the non-touchscreen models..i found this problem a while back and have sent storey the bcm model number ..its a matter of waiting until storey figures it out ... ... - .- -.
Post #62367 2nd May 2011 10:01am
snugg
Thnaks once again scarey.
Post #62404 2nd May 2011 6:35pm
there's massive potential for this unit , its just a matter of waiting for the software to get updated... ... - .- -.
Post #62415 2nd May 2011 9:04pm
sportin
I am going to be using it on a MY06....MY06 still has some systems that the 2005 and older have, so it will be interesting to see what it can actually do... Idea 2006 RR 4.4 HSE
2008 Audi A6
Post #62794 5th May 2011 11:50pm
RSW All-Comms in Use
Trying to keep things in place Wink
After putting things back together I ran and re-ran diagnostics with my all comms, getting some recurring faults, some more obvious than others:
FFRR - RSW All-Comms Report
6/11/11
ABS
Steering angle sensor initialisation.
AIR SUSPENSION
CAN bus Fault.
BODY CONTROL
Passenger door central locking mechanism short-circuit.
ENGINE IMMOBILISER
Power-on Reset.
HEVAC
Aspirator motor fault.
INSTRUMENT PACK
EBV function fault received from ABS ECU.
LIGHTING
Air suspension active/inactive.
Right side marker defective.
SECURITY ALARM
Coding checksum error.
TRANSMISSION
CAN bus brake signal fault General fault
Interesting - no problem with right side marker, can't clear the CAN bus faults. Clearing most faults seems to have got rid of my HDC Inactive message on startup though.
Anyone had the Aspirator Motor fault on HEVAC - what is it?
[EDIT - found on LandyZone - "the aspirator motor is in the air conditioning ecu (control panel), its the motor that spins behind the control panel to draw air in to measure the ambient temp, so if this sticks or fails then wrong reading will occur"] My heating and aircon all seems to work OK.
or this one:
CAN bus brake signal fault General fault?
and what the heck is this all about:
EBV function fault received from ABS ECU? .
Post #90671 6th Nov 2011 2:50pm
Swast (Adam) was getting the can bus fault and went through loads to get it sorted but he had his tracking and steering angle reset and it sorted his abs and can bus errors. Mthe HVAC could be the FSR? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #90683 6th Nov 2011 4:04pm
we seem to have a new update which gives us a new tab with 'activation' written on it..i cant enter into the software so i suppose we have to connect to the unit for the software to be accessed..
also there are chinese copy's of storeys unit bouncing about which will not work with the software..
Post #96718 8th Dec 2011 1:58pm
Have you told storey about the copies? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #96728 8th Dec 2011 3:21pm
