Home > Technical (L322) > Rover All Comms - First Look |
sportin Member Since: 12 Mar 2011 Location: USA Posts: 26 |
I have MY2006....I'm interested to see if this will work on it. I know the vin stops 5A999999, but the 06MY still some BMW systems... Just my luck, I will need to this one and the new top secret model to cover all of the systems in the 06MY waaaaayyyyy 2006 RR 4.4 HSE
25th Apr 2011 12:27am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35246 |
available today according to the website.. ... - .- -.
25th Apr 2011 11:08am |
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 |
My 07MY (late 06 production) FFRR has the triple flash indicators. Perhaps suggesting it was the 06/07 onwards cars with the updated interiors that had the triple flash 'lazy' indicators?
26th Apr 2011 9:12am |
hi snugg, if you mean 'problems i am having' then the answer is none at the moment..i got it just in case i need to clear a fault in the future and for the extras it can do .. ... - .- -.
27th Apr 2011 7:20am |
snugg Member Since: 16 Jun 2010 Location: Maryland Posts: 29 |
Ok, thanks alot scarey! |
27th Apr 2011 4:02pm |
Has anyone with a 2005 (touch screen) been able to get the RAC body module function to work? I am able to read and clear faults, but when I enter the body control function, it does not read what the current settings of the truck are. Also I tried to turn on the emergency siren and nothing happened.
1st May 2011 10:11pm |
snugg, mine is the same as yours and i have the same problem..apparently the bcm [which is under the passenger seat] is different to the non-touchscreen models..i found this problem a while back and have sent storey the bcm model number ..its a matter of waiting until storey figures it out ... ... - .- -.
2nd May 2011 9:01am |
Thnaks once again scarey. |
2nd May 2011 5:35pm |
there's massive potential for this unit , its just a matter of waiting for the software to get updated... ... - .- -.
2nd May 2011 8:04pm |
I am going to be using it on a MY06....MY06 still has some systems that the 2005 and older have, so it will be interesting to see what it can actually do... 2006 RR 4.4 HSE
5th May 2011 10:50pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Trying to keep things in place
6th Nov 2011 1:50pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Swast (Adam) was getting the can bus fault and went through loads to get it sorted but he had his tracking and steering angle reset and it sorted his abs and can bus errors. Mthe HVAC could be the FSR? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
6th Nov 2011 3:04pm |
we seem to have a new update which gives us a new tab with 'activation' written on it..i cant enter into the software so i suppose we have to connect to the unit for the software to be accessed..
8th Dec 2011 12:58pm |
Have you told storey about the copies? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
8th Dec 2011 2:21pm |
