![]() | Home > Technical (L322) > Rover All Comms - First Look |
sportin Member Since: 12 Mar 2011 Location: USA Posts: 26 ![]() ![]() ![]() |
I have MY2006....I'm interested to see if this will work on it. I know the vin stops 5A999999, but the 06MY still some BMW systems... Just my luck, I will need to this one and the new top secret model to cover all of the systems in the 06MY |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
available today according to the website.. ... - .- -.
Olders Member Since: 17 Mar 2011 Location: Suffolk Posts: 115 ![]() ![]() ![]() |
My 07MY (late 06 production) FFRR has the triple flash indicators. Perhaps suggesting it was the 06/07 onwards cars with the updated interiors that had the triple flash 'lazy' indicators?
hi snugg, if you mean 'problems i am having' then the answer is none at the moment..i got it just in case i need to clear a fault in the future and for the extras it can do .. ... - .- -.
snugg Member Since: 16 Jun 2010 Location: Maryland Posts: 29 ![]() ![]() ![]() |
Ok, thanks alot scarey! |
Has anyone with a 2005 (touch screen) been able to get the RAC body module function to work? I am able to read and clear faults, but when I enter the body control function, it does not read what the current settings of the truck are. Also I tried to turn on the emergency siren and nothing happened.
snugg, mine is the same as yours and i have the same problem..apparently the bcm [which is under the passenger seat] is different to the non-touchscreen models..i found this problem a while back and have sent storey the bcm model number ..its a matter of waiting until storey figures it out ... ... - .- -.
Thnaks once again scarey. |
there's massive potential for this unit , its just a matter of waiting for the software to get updated... ... - .- -.
I am going to be using it on a MY06....MY06 still has some systems that the 2005 and older have, so it will be interesting to see what it can actually do... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Trying to keep things in place |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Swast (Adam) was getting the can bus fault and went through loads to get it sorted but he had his tracking and steering angle reset and it sorted his abs and can bus errors. Mthe HVAC could be the FSR? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
we seem to have a new update which gives us a new tab with 'activation' written on it..i cant enter into the software so i suppose we have to connect to the unit for the software to be accessed..
Have you told storey about the copies? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
