Home > Maintenance & Mods (L322) > ABS ECU, the 3 Amigos & steering angle sensor issue
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi guys, I’ve got an issue related to the 3 Amigos on the dash. When I checked the cause on my icarsoft handheld it told me I had a ABS Ecu fault so I swapped it out for a spare. Put it back on the computer, clears the faults & all ABS faults now gone except the 3 lights, abs, traction & hill decent are still on. Now I check again & I get “steering angle sensor initialisation” so I do the lock to lock on start up with the steering but it did nothing.
Any ideas what I need to do now as that “steering angle sensor initialisation” was not showing before I swapped out the abs ecu. How do I get the lights off?
Regards
Paul
 2004 RR 4.4 V8 Autobiography
Post #533318 6th Nov 2019 2:39pm
stu1
Yes, you need to initialise the steering angle sensor (it needs doing if the ABS ECU is renewed).
The IIDTool can do this.
Post #533341 6th Nov 2019 6:23pm
PaulM
Ok thank you. Only thing is I don’t have an IID tool. Would a computer from a typical garage be able to do this or does it have to be Land Rover specific? 2004 RR 4.4 V8 Autobiography
Post #534038 13th Nov 2019 10:40am
stu1
Don't know sorry, I used an IIDTool.
Post #534120 13th Nov 2019 6:58pm
Rewmer
You need to get the replacement coded to the car otherwise it will always show the 3 amigos. This can’t be done with IID. You need either T4 or Autologic No7 - 2003 V8 Vogue
Post #534733 18th Nov 2019 8:41pm
Danwilderspin
all comms will do it too... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534767 18th Nov 2019 10:37pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
did mine with iIDtool BT with out issues
Post #534783 19th Nov 2019 12:32am
Rewmer
Steering angle sensor calibration yes, not coding though. It will always show the lights until it’s coded No7 - 2003 V8 Vogue
Post #534798 19th Nov 2019 10:11am
