Home > Maintenance & Mods (L322) > ABS ECU, the 3 Amigos & steering angle sensor issue |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
Hi guys, I’ve got an issue related to the 3 Amigos on the dash. When I checked the cause on my icarsoft handheld it told me I had a ABS Ecu fault so I swapped it out for a spare. Put it back on the computer, clears the faults & all ABS faults now gone except the 3 lights, abs, traction & hill decent are still on. Now I check again & I get “steering angle sensor initialisation” so I do the lock to lock on start up with the steering but it did nothing.
6th Nov 2019 1:39pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Yes, you need to initialise the steering angle sensor (it needs doing if the ABS ECU is renewed).
6th Nov 2019 5:23pm |
Ok thank you. Only thing is I don’t have an IID tool. Would a computer from a typical garage be able to do this or does it have to be Land Rover specific? 2004 RR 4.4 V8 Autobiography |
13th Nov 2019 9:40am |
Don't know sorry, I used an IIDTool. |
13th Nov 2019 5:58pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
all comms will do it too... Current stable:
18th Nov 2019 9:37pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
did mine with iIDtool BT with out issues |
18th Nov 2019 11:32pm |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 |
Steering angle sensor calibration yes, not coding though. It will always show the lights until it’s coded No7 - 2003 V8 Vogue |
19th Nov 2019 9:11am |
